Results 1 to 10 of 21
Thread: DAytime running light activation
    Events Manager & Moderator jon1.9cdti's Avatar
    Swanley , Kent
    127 Post(s)
    Vehicle : Sports Tourer
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Default DAytime running light activation
    After buying a happylightshow the other month for drl,s among other things I found last week they can be turned on by opcom/tech2
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Yup. KenP will confirm, sure you can have Headlights or Foglights activated to run as DRL on the Vec.
    Jul 2009
    Yorkshire
    Quote Originally Posted by jon1.8sri View Post
    So does opcom also turn on corner lighting, DPF regen light, alarm chirp, welcome lighting via keyfob, dashboard needle sweep etc etc??
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Nope tech2 or equal kan only do DRL and force regneration, but yes theres a option in REC for rear lights as drl, and in UEC for the normal lights. (on some one of the settings uses the front foglights, but only on some, not on mine)
    Swanley , Kent
    127 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    I could get it to do sidelights or sidelights and dipped beam
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Facelifts had the option in the UEC for front foglights as DRL's, but pre-face only activates sidelights or dipped beam.
    Tried all 4 DRL options on mine using the program that must not be mentioned, and preface only works with DRL option 1 & 2. Tried options 3 & 4 on a friend's facelift and it uses the fogs.
    Swanley , Kent
    127 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    I will have to check mine again then as mine is facelift and 3 & 4 did not appear to do anything,
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    i used tech2 and they can activet drls no probs
    Engine : 2.2 Direct
    Not working on all..
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    178 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Quote Originally Posted by kenp View Post
    Ken, for a pre-face 04 gsi do you know if both front and rear sidelights are activated together as DRL's or can you choose front, rear, or both using the tech2 ?
  1. auto headlight switch AND daytime running light
    By nipmads in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2012, 08:18
  2. Retro fit Daytime Running Light Wiring
    By yorkshire jim in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2012, 23:23
  3. difference between daytime running lights and daytime styling lights ????/
    By montyfert in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2012, 13:09
  4. Daytime running led strips
    By bigal77 in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2012, 13:11
  5. Daytime Running Lights
    By R2XPT in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2010, 10:57
daytime running light rec vectra c
