Results 1 to 10 of 11
Thread: Doing my head in now...
    Lincoln
    Default Doing my head in now...
    ok so been having probs with my vectra now for 4 days when you leave it over night car wont start but if you open the injectors the car starts up and runs like it should no problems drove for about 2 hours this afteroon all good ive change the leak off pipes just the pipe not the t piece as no stock at the time..and fuel filter, still no good..no errors code or eml or spanner,
    so im guess its the fuel pump
    Aug 2010
    Leeds
    Is there bubbles coming out of the injector pipes when there loose and your cranking?
    Lincoln
    yeah there is
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Injector seals i expect
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Your drawing air into system somewhere
    Need to check all the lines and connections
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    as I posted in other thread , use genuine leak off pipe as it is critical on these pumps , go from there .
    Aug 2010
    Leeds
    The bubbles are trapped air in the system which is been dragged in so as said above fit the genuine thing plus any seals.
    Copper washers replace these and the injector seal it's a copper washer.
    At least you know the pumps ok as it's running.
    Lincoln
    Quote Originally Posted by Bigtee View Post
    yeah very true i guess i cant do injector seals my self as you have to take camshaft apart or sumit im not to great with cars tbh
    May 2012
    county durham
    Mileage : 145k
    so do the leak off pipes & see how it goes , it may well be cured after that .
    Lincoln
    Quote Originally Posted by DTi Elite View Post
    ok Many thanks for your help ill do them and repost thanks again
  1. Head gasket or head?
    By GCusdin in forum Engine & Drivetrain
    Last Post: 28th December 2012, 17:37
  2. what a **** head
    By rickeys16v in forum General Chat
    Last Post: 24th May 2010, 01:16
  3. Front head rests/rear head rests
    By mickontherun in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2008, 23:29
  4. Front head rests/rear head rests
    Last Post: 12th July 2008, 22:47
  5. A new head for my vec
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2006, 04:25
