Results 1 to 2 of 2
Thread: LED Footwell and gearstick change
    Regular Member JAMMUR's Avatar
    Apr 2012
    Elderslie, Scotland
    Default LED Footwell and gearstick change
    Hi all,
    Wondering if someone could help me out. Im looking to install blue LED's in the Footwells of the passenger and driver side, does anyone know of a guide ? Also looking to change the Gearstick to an aftermarket one, is this hard to do ?
    Thanks in advance
    Jamie
    Jul 2011
    UK
    Year : 06
    The footwell lights is a simple job very easy
    Remove the interior light and sunglasses holder few torx screws
    Then twist one of the bulb holders on the light and push wire down each side of the holder and refit the bulbs
    Fit light holder back in
    Feed the wire to the foot well
    Connect wire to bulb or lights I got boot lights for this and cut a hole the same size as the holder looks factory
    Job done
    Gear stick I went for the Astra h 6 speed stick
    Remove the gaitor
    Ul see 4 torx screws remove these
    Then to the right at the bottom ul see a cable with a clip connector unclip this then it will come off
    Swap the gaitors over
    Fitting is vis versa
  1. Gearstick
    By dilan in forum Bodywork & Interior
    Last Post: 5th August 2012, 00:19
  2. vxr gearstick
    By toughmat in forum Styling
    Last Post: 1st April 2012, 22:40
  3. Vac c gearstick
    By Paddy in forum Bodywork & Interior
    Last Post: 10th October 2011, 21:53
  4. gearstick change?
    By larann in forum Styling
    Last Post: 1st August 2011, 23:45
