Thread: Handbrake adjustment
    swansea
    Default Handbrake adjustment
    Following on from the 'brake bleeding' post, how is the handbrake adjusted, after changing one rear caliper, discs and pads.
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    The handbrake self adjusts but you can reset it in case u took up some of the play with the handbrake and not the foot pedal.
    swansea
    How do you reset it?
    Aug 2010
    Leeds
    Wind in both calipers and pump the brake pedal after you fit new pads etc.
    Jul 2012
    How do you wind the cable up a bit so the handbrake doesn't come up as much.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Disconnect Habdbrake at calipers pump brake pedal 20 times.
    Refit at calipers pump pedal an hold down
    Pull up on handbrake
    release foot brake
    release handbrake
    pull up on handbrake adjustment should be better now
    Jul 2010
    This is London baby
    Trim : SXT
    Year : 2010
    Mileage : 53000
    Or you can do it from inside the car, there is a thread how to do it.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    are you shore
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Don't think you can. Well I've not seen it. Thought it was an automatic adjuster?
    Jul 2010
    This is London baby
    Trim : SXT
    Year : 2010
    Mileage : 53000
    You can i did this on mine (the stupid garage used the handbrake rather than pumping pedal first) and got two clicks less. Under the cubbyhole/ arm rest there is a spring what you have todo is press the sliver thing down and press in the spring at the same time (from what i can remember i found out how to do it on here)) and that resets the adjuster pump pedal a few times then pull and release the handbrake a few thime to set. if its still high then i would think a new cable will be needed.
  1. handbrake adjustment???
    By craigleeds in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2011, 03:43
  2. Handbrake adjustment
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 16:20
  3. MPG adjustment on Op.com
    By mally in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 12:40
  4. 1.8 sxi handbrake adjustment
    By Paul4274 in forum Suspension, Wheels & Brakes
    Last Post: 12th June 2009, 16:26
vectra c handbrake reset www.vectra-c.com
2004 vectra handbrake adjustment
vectra c handbrake adjustment
