Thread: tight space
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Default tight space
    fitting new single din headunit with steering wheel controls, prob is when i try to fit all the wires into the small space the unit wont power up, when i untangle all the wires it works, its just when the wires are all squachwd behind the unit it stops, if i removed the glovebox would i be able to feed the wires in behind more easely.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Should be able to get your hand in an pull the wired out the way with glovebox out
    ijk571
    Guest
    Quote Originally Posted by Critch View Post
    Regular Member stephen_brady's Avatar
    Jan 2012
    N.Ireland
    Try rotating all the wires round and it pulls it into a tighter bundle. I had to this with mine.
    Regular Member opel_estate's Avatar
    May 2008
    Sweden
    Vehicle : Opel Vectra C Estate
    Trim : Enjoy
    Engine : Z22YH
    Mileage : 55000
    Aah, the old "brady bunch" trick
    Jul 2011
    UK
    Year : 06
    With mine I took the vents of and screen in middle then as I pushed the unit in I pushed the wired down the back and to the sides also removed the glove box and gently pulled the wires as I pushed in the head unit
  1. Tight Van Man
    By Big Dave in forum General Chat
    Last Post: 16th June 2011, 11:07
  2. And you think your area is tight for parking space.
    By signum_rob in forum General Chat
    Last Post: 1st April 2011, 15:45
  3. Why is Vx so tight?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2011, 03:37
  4. Replies: 15
    Last Post: 2nd August 2009, 00:11
  5. hee hee im a tight wad!
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2006, 21:57
