Results 1 to 10 of 25
Thread: Bosch VP44 Diesel Pump 2.0 DTI
    Lincoln
    Default Bosch VP44 Diesel Pump 2.0 DTI
    if the Diesel pump is Knacked in the Car would it start and all and run??
    also can i just buy a 2nd hand on and stick it on or is progamed to the ECU
    Thinking of getting rid nothing but trouble
    Barrow In Furness, Cumbria
    I think it's programmed to the ecu, but think you can change the electrics over. From memory though it's those that break down in the first place.
    Lincoln
    ok cheers would the leak off pipes stop a car from starting ??
    morecambe
    36 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    The ecu is connected to the pump needs to programmed in but needs to be devorced frOm the ori cars ecu.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    lad at work has a zafira dti (same pump ) and that has just died , p0340 fault code which points to cam sensor ( until some research is done ) still starts & runs sometimes but runs really rough .
    Lincoln
    my car runs fine once started but wont start if left to long
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Quote Originally Posted by Madmarky01 View Post
    That sounds like the leak of pipes.
    If you park it over night facing down hill, does it start then?
    If so, then thats a good sign its your leak of pipes.
    Lincoln
    yeah i changed them yesterday and was ok last night around 10pm started first turn no problems just been out it the car and now wont start
    It's not the leak off pipes then. I went through all sorts with my Vec B, but gave up as I wasn't getting anywhere. I know it doesn't help, sorry.
    Have you seen the post of a sensor you disconnect before starting? Think it's in the diesel section?
    Lincoln
    Quote Originally Posted by Chris SRi View Post
    nah what sensor??
  1. Bosch fuel pump vp44 2.2dti
    By davesignum1988 in forum Engine & Drivetrain
    Last Post: 12th September 2011, 13:41
  2. diagnosing faulty bosch vp44 pump
    By lenny32 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th August 2011, 22:56
  3. swapping bosch vp44 pump?
    Last Post: 14th July 2010, 17:23
  4. swapping bosch vp44 pump
    By lenny32 in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2010, 11:42
  5. Diesel Pump?
    By jrpatten in forum Engine & Drivetrain
    Last Post: 14th February 2009, 21:47
