Likes Likes:  1
Results 1 to 10 of 22
Thread: P0234 Fault resolved on 2.2 DTI
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Default P0234 Fault resolved on 2.2 DTI
    Afternoon all
    For those that keep getting P0234 fault, it's worth looking at the Boost control solenoid for answers, as i've just found the thing is adjustable!
    I've recently been getting limp mode with P0234 followed after diagnostic, so last weekend, i decided to fit a boost gauge. Boost was erratic, never smooth, and most of the time was showing 1.5Bar overboost before settling down to 1Bar a few seconds later. There's no splits in the hoses, and the vacuum pipes are all silicone replacements. Only leaves the turbo and the boost valve, and being lumpy, i decided to tackle the VNT mechanism on the turbo.
    After spending most of the afternoon trying to dis-assemble the turbo to try the Mr Muscle VNT cleaning method, i've found my turbo to be relatively clean (on a plus point, no play in the bearings ) and the VNT mechanism and arm moves fine without any resistance (checked while actuator rod disconnected). So i though, it can't be the turbo then
    Disconnected the boost control solenoid, took it apart and cleaned it. Noticed in the base there was a hex screw, so i tried seeing if there was any movement in it, and tightened it up. Re-fitted it and took it for a test drive, and had to drive it gently back home after the boost gauge was nearly whacking up to 2Bar with no sign of reducing. After some head scratching, i decided to unscrew the the hex screw back to where it was, and loosen it one full turn. Put it back together, and bam! 1Bar steady with 1.2Bar overboost
    Drives much better and boost comes on a lot smoother too! Done about 20 miles since and the boost readings are consistent
    I'll do a full write up if anyone wants to try it themselves!
    Jul 2012
    Warrington
    yea write up sounds good and do you have a picture od where the boost solenoid is ive onnly had the car 2 weeks and trying to get my head round it all cheers
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    get it wacked up full chat mate lmao top job
    Nov 2011
    Quote Originally Posted by paulvectrac View Post
    It holds back and throws P0234 if it goes anywhere near 1.5-2Bar when i've been test driving it. Would need a remap for higher boost
    I'll get some pics and do a write-up over the next few days
    Nov 2011
    400 miles done since, booted it hard uphill in 5th and it didn't bat an eyelid! Powered on like a trooper, 1Bar pressure and no warnings
    Well happy now
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Hi mate.im getting the same on my 2.0 dti.can you post a how 2 or some pics.im sick as a pig with mine.boost sensor change as well hasnt worked.do you mean tge wastegate solenoid or the egr solenoid?ta
    Nov 2011
    Sorry chaps, totally forgot about this thread, I'll get some pics up and a guide at the weekend (too dark to do it after work)
    Nov 2011
    Talking
    Right guys, here's a quick run-through. Apologies for the delay.
    Only attempt this if you have thoroughly checked ALL of the following:
    Vacuum lines for leaks and holes
    All turbo intake and intercooler pipework for splits and leaks
    VNT actuator rod movement (check that it moves freely and does not stick)
    Tools you will need:
    10mm Socket wrench or spanner
    HW5 Hex bit or T30 Torx bit
    Small flathead screwdriver
    Carburetor cleaner
    Soft cloth
    Cable ties
    Okeydoke, Here goes...
    The turbo actuator solenoid is located next to the battery cover
    Undo the two 10mm nuts holding the solenoid to the bracket.
    Disconnect the wiring plug from the solenoid, then remove the vacuum pipes. (refer to pic for refitting)
    Spray the carb cleaner into either of the tubes for about 30 seconds, repeat on the other tube. At this point, refit the solenoid and roadtest. If there is no difference, next you need to take off the solenoid top. Use the small flathead screwdriver to gently push away the clips and very carefully remove the top to access the diaphagm (I say carefully as there's 2 springs inside that want to re-enact the Great Escape). Make a note of which order the innards are placed to aid re-assembly (i've seen some valves completely different to mine, so note how yours is assembled). Clean the diaphragm and small rubber pad with carb cleaner and a soft cloth. once cleaned, re-assemble and use the cable tie to squeeze the top clips in place if you've accidentally broken any. Re-fit and roadtest.
    If this has not resolved your issue, I strongly recommend for the next step, a use of a Boost Gauge or Tech2/Vauxcom (or other) that can show turbo pressure readings.
    Ok, remove the solenoid again, and gently prize away the clips on the bottom cover to access the adjustment screw.
    You will need either a HW5 hex, or a T30 Torx bit for the adjustment
    With the cover removed, turn the screw half-turn anti-clockwise, re-assemble, refit, and roadtest. Repeat again until your boost reading reads a steady 1 Bar (14psi) with full throttle. Brief overboost to 1.2 bar is acceptable as long as it drops back to 1 Bar with full throttle.
    Once it's sorted, have yourself a Beer, and relax.
    I hope this helps you guys!
  9. Likes deco016 liked this post
  10. #9
    Jan 2012
    GREECE / PATRAS
    thanx mate!!! I have the same problem i will do and see the results!!!
  11. #10
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    How did you fare out with this now its been done a while
  1. P0234 -5B Fault
    By frenchman in forum Engine & Drivetrain
    Last Post: 30th November 2012, 01:02
  2. Fault Code P0234 - Boost Pressue
    By Gazz in forum Engine & Drivetrain
    Last Post: 15th October 2012, 10:48
  3. P0234 fault code, can anyone help.
    By Hyperhart in forum Vectra C / Signum Troubleshooting
    Last Post: 27th August 2012, 08:12
  4. P0234 Overboost Fault Code
    By harrison1987 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st January 2012, 20:57
  5. vectra 2.2dti p0234 fault!!!
    By welshrugfan in forum Engine & Drivetrain
    Last Post: 17th November 2008, 13:17
vectra 2.2 dti p0234
opel vectra 2.2 p0234
p0234 vauxhall
p0234 vectra c 2.2 dti
p0234 opel vectra c
vectra c 2.2 dti overboost problem
p0234 opel 2.2dti
p0234 vectra c
p0234 opel zafira 2.0 dti
p0234 opel vectra c 2.2
zafira 2.2 dti code defaut p0234
p0234 vectra 2.2
2.2 tdi vectra earth fault
opel p0234
p0234 opel zafira 2.2 dti
2.2 dti to 2.0 turbo www.vectra-c.com
opel 2.2 dti greska p0234
vxr p0234
p0234 opel vectra tdi c 2003
2.2 dti p0234
p0234 vauxhall 1.9cdti negative deviation
opel signum 2.2dti p0234
