Results 1 to 2 of 2
Thread: Number plate light problem.
    Regular Member carperjake's Avatar
    Scunthorpe
    Trim : Elegance CDTi 120
    Engine : 1.9
    Default Number plate light problem.
    Noticed a blown number plate light recently (off side). Went to change the bulb today and the screws are corroded to hell, no way of removing them, so I decided to remove the inner rear tailgate trim and attack it from the inside. Got access to the underside of the mount that the lights and handle are in easily enough but when I changed the bulb it still didn't work, TBH it didn't look blown as the filament looked intact but it was definately darker. Swapped the mounting to the other side and it worked ok, so i know the mount is good. This leaves either the plug, a fault in the wiring or a fuse. Is there a seperate fuse for each number plate light? I've had a look in the handbook and can't find any reference to a number plate light fuse.
    Any ideas?
    Scunthorpe
    Engine : 1.9
    Sorted. Managed to take the unit apart and found that one of teh contacts was covered in corrosion. 2 mins with some wire wool and it's sorted.
  1. Number plate light
    By ronaldodg9 in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2012, 05:18
  2. Number plate light problem
    By namwen in forum Electrical & ICE (including SatNav)
    Last Post: 5th September 2011, 19:24
  3. Tail light/number plate light wiring...
    By kyuudousha in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 12:34
  4. New Smd 501 sidelights and number plate light
    By 3.2wales in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2009, 22:51
  5. Number Plate Light
    By kiwigolfer in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2009, 23:10
vauxhall vectra number plate light fuse
vectra c number plate light fuse
