Thread: 1069 fault code whats this
    Worksop
    Default 1069 fault code whats this
    Any ideas
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    I can only find this
    U1069 SCP (J1850) Invalid or Missing Data for Primary Id
    Worksop
    Also got 1617 and 0235
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 134000
    what model do you have ?
    i found
    P0235 Turbocharger Boost Sensor A Circuit Malfunction
    Worksop
    2.0t bud
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    P1069 is the Barometric Pressure sensor aka the MAP sensor... the main one i know of on our engines is in the boost pipe half way up from the intercooler to the throttle body.. Its in the top end of the plastic section.. There may also be another one on the inlet manifold as well.. Take it/them out and give them a clean up..
    P1617 I always thought this meant your service is coming up and the service light will be due to switch on...
    P0235 point to one of the boost solenoids, probably the one by the ECU.
    I would start with cleaning you MAP sensor(s) first and clear down you codes with battery reset if your code reader can't do it..
    Worksop
    Quote Originally Posted by Caveman_nige View Post
    Cheers nige yeah the insp light is coming on so that is one of them boost sensor witch one is it near the actuator
  1. Fault code help!
    By joee91 in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2012, 00:52
  2. whats in a code
    By rayeg1935 in forum Engine & Drivetrain
    Last Post: 5th April 2012, 23:17
  3. fault code
    By stresshead in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd March 2012, 14:24
  4. Whats best to look for with these fault codes?
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2011, 16:25
  5. whats my engine code ??
    By renton608 in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2011, 21:29
