Thread: A slightly different aircon question!
    Regular Member GoldenWonder's Avatar
    Durham
    Default A slightly different aircon question!
    Ok, so my aircon must be leaking somewhere after being regassed 5 times in 4 months but the garages can't find a leak.
    I've had a good look at all the pipes, compressor and condenser today to see if I can see if any dye is showing. But it only just occurred to me, is the dye they use in aircon visible without a special light?
    I remember watching an episode of Wheeler Dealers where they put dye in the aircon and it was luminous green/yellow but someone also told me it can be a dye that can only been seen with a UV light?
    Is either/both true? My condenser looks a bit battered but there's no green stains showing, and the speed it loses pressure it should be pretty obvious!
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    its normally uv dye .
    Regular Member dave1419's Avatar
    Jun 2012
    newcastle upon tyne
    9 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    Hello,the guy who checked mine out ond found a leak used a luminous green dye-think it was green just for the human eye to see,he told me that condensers leaking are common on veccys,The lad is called Richard and he come from Gateshead-if my memory serves me well--his number is-07890656586. Im sure he won't mind me putting his number up on here-hope its ok with the Mods too.He is a sound lad and he found a leak on mine and it was repaired under warranty-otherwise he would of done it for around 50% cheaper----Dave
    Durham
    Cheers. Sounds like it could be either then! I guess replacing the condenser is the next step but the garage won't pay for that under the warranty as they havent found a leak!
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    UV lights are cheap enough, perhaps buy one and have a good look around everything including the interior near the heater box.
  1. AirCon Question
    By RobW in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2010, 21:12
  2. aircon question
    By monty2000 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th June 2010, 13:49
  3. Aircon question
    By 67688c in forum Heating, Ventilation & Air Conditioning (HVAC)
    Last Post: 15th April 2010, 02:55
  4. Sorry Another Aircon Question
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2008, 11:14
  5. Slightly uneven idle when aircon is switched on?
    By Hideous in forum Engine & Drivetrain
    Last Post: 1st August 2007, 18:08
