Thread: 2.0t boost trouble keep losing the turbo
    Worksop
    Default 2.0t boost trouble keep losing the turbo
    As above keep losing boost but when I switch off and on again it's back to normal fitted new air by pass valves still no better any ideas
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    have you check the codes and checked for split or disconnected pipes etc?
    Worksop
    I can't check codes only got a cheap scanner and when spanner light comes oon it not show anything
    Jun 2009
    South Coast
    so you do get the spanner light on, ok we are getting somewhere...
    have you tried thee pedal method for code reading... http://www.vectra-c.com/forum/showth...-any-Equipment
    Worksop
    Ok nige will try later last time I had it checked it were boost sendor
  1. losing boost sri 2.0t really annoying
    By tomo41 in forum Engine & Drivetrain
    Last Post: 22nd August 2013, 23:41
  2. 1.9 150 CDTI losing power/boost
    By jay w in forum Engine & Drivetrain
    Last Post: 26th February 2012, 22:57
  3. Keep losing the turbo switch on/off working again
    Last Post: 9th October 2011, 21:25
  4. losing boost pressure
    Last Post: 10th July 2011, 16:35
  5. Replies: 7
    Last Post: 27th November 2009, 19:43
