Results 1 to 10 of 14
Thread: Computer help needed
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Default Computer help needed
    Hi
    Need some help with regards to my xp pro system.
    Yesterday i installed pc tools registry mechanic and let it do a scan as i was having a couple of small issues. said it found some issues in the registry so i allowed it to fix them.
    Today it is goosed. Boots to desktop and the task bar wont load nor will any icons i click on, just says i may not have permission etc.
    tried to access system restore through cmd promt, says the same.
    So i tried to repair via the recovery console and when i type in the first command as instructed from here http://support.microsoft.com/kb/307545, just says access denied.
    so tried to enable the set command option by doing the following
    SET AllowWildCards = TRUE
    SET AllowAllPaths = TRUE
    SET AllowRemovableMedia
    = TRUE
    Says the same again, access denied. After doing a bit of reading it says i have to enable withing windows. But i can access anything via windows.
    Can some body please help as i have a lot of important stuff on the computer and i cant access anything
    cheers
    Regular Member ZWoodyz's Avatar
    Jun 2012
    North lincs
    Can you get on In safe mode (press F11 on startup) ?
    Regular Member Craig1985's Avatar
    harwich essex
    F8 on dell machines I think? Keep pressing it and truly a restore in safe mode
    South east
    Are you sure it was a genuine and safe registry repair tool, and not a scam version that's designed to break your PC?
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Safe mode won't let me into anything either, any other ideas guys
    May 2011
    bispham, blackpool
    when loaded up in safe mode odds on you will be seeing nothing no icons no task bar at the bottom.
    try getting task manager up by pressing all at the same time ctrl,shift,esc
    if it comes up click the file tab, then go to new task (run),
    from their you can type explorer.exe and hit enter. This should bring everything back up so you can get to add and remove and remove the program you installed.
    if this doesn't do anything then you need to get rid of everything off your startup menu
    try the same to get task manager up,new task, and type in msconfig, if a new window comes up with the title of system configuration then click the start up tab and unclick everything save and restart in normal mode it should be back to normal, then go to add and remove and remove the program you installed. then you need to go back in to system configuration and re tick all programs needed IE drivers.#
    if none of the above works then it would be easier to reload it
    (had a good few JD and cokes so sorry if it doesn't make sense lol just email me will answer when im sober)
    also none of the command prompt would of worked as odds on you will not be logged on as the administrator
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    i cant wipe my computer tbh as i have photos on it and i can even copy them. for some reason any app that i click is blocked, says no permissons etc. ive even tried to install virus scanner from usb/cd and that wont open either. anything else to suggest? cheers
    Regular Member Lozza's Avatar
    Jun 2011
    Brum
    Vehicle : Vectra c
    Trim : SRI
    Engine : 1.8
    Year : 06
    when u open cmd prompt, can you "run as admin" or have a look at this m8
    http://support.microsoft.com/kb/304449
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Hi Mate
    Do you have an external usb Hard disk drive. If so I can send you a bart pe cd with some tools on it to enable you to backup your data onto the external drive.
    You can then wipe and resetup windows cleanly and then put your data back on.
    PM if you are interested. I can supply an external HDD too if you dont have one.
    WGAF#5
    As above try safe mode boot up and THEN system restore to prior to the software install ...hopefully then this will allow you to get back to where you were
  1. Computer Help Needed..
    By macdad in forum General Chat
    Last Post: 15th November 2009, 21:39
  2. computer help needed please...
    By ditchp in forum General Chat
    Last Post: 21st June 2009, 21:24
  3. Computer help needed...........please
    By silverhairedracer in forum General Chat
    Last Post: 29th December 2008, 16:21
  4. Computer help needed
    By Ste in forum The 'Off Topic' room
    Last Post: 21st May 2008, 10:59
  5. computer help needed
    By vectra 2.0 t in forum General Chat
    Last Post: 27th January 2006, 20:17
