Thread: Fk street coilovers -setup
    Apr 2011
    essex
    Default Fk street coilovers -setup
    Hi had my fk street coilovers fitted. I preset it to 15mm adjustment left on front and rear.
    Problem is the front isn't really that low but the rear is dropped below the tyre. Way too low! Looks like the rear suspension is broken
    I tried to upload pics but keeps saying pics too big and trouble resizing on my iPad.
    Anyway had a question checked on the rear they didn't fit the rubber tops back on above the adjuster. Did anyone with same setup fit it on above adjuster?
    May 2011
    bispham, blackpool
    Mine are a different make but they look the same sort of set up I kept all rubbers on the back as I thought it would help with any sounds coming from springs. (metal on metal)
    But looking at the picture on my phone it looks like its low.
    Would love mine to look that low
    Sent from my HTC Wildfire using Forum Runner
    Regular Member stephen_brady's Avatar
    Jan 2012
    N.Ireland
    Is this not because the front arches are higher due to the body work of the car rather than the suspension or chasis being set up at an angle. I'm pretty sure that providing your measurements are right your chasis may well be level. It's just the cut of the arches creating the appearance that the rear is lower. If it really irks you, you can consider dropping the rear by up to 5mm less which look more balanced and may also improve handling and prevent the rear end sliding out.
    Apr 2011
    essex
    I took it down to elite direct in Essex to have it aligned and they advised I don't need to refit the rubber. I'll raise it a bit at the back. I know what you mean by the arches not being on different heights.
    Just wondering if anyone with fk setup runs with front all the way down? Doesn't seem that low at the front at the moment
    Btw I'm running 18's
    Jan 2012
    N.Ireland
    Is it easy to adjust at home? Was thinking of , lowering mine so was considering coilovers for flexibility
    Apr 2011
    essex
    It's not very straight forward to adjust the rears. You still need to loosen off the shock to release tension in the spring or the adjuster won't turn. But you do get to setup height exactly how you want. It might help if I could jack up both sides but I only have one jack
    Im quite pleased with the ride speed bumps are a bit harsh especially the really sharp ones. The roads are not too bad cornering is much better I had 30mm eibachs on but still too much roll for me and the front was too high
  1. Street Car / Zip Car
    By ryantcb in forum General Chat
    Last Post: 27th July 2011, 19:42
  2. NFS: Pro Street PS3
    By breezephil in forum General items for sale
    Last Post: 12th February 2008, 07:49
  3. Street names on sat nav
    By rosssri in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2007, 15:05
  4. Street/off street car parking rules
    By cavester in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2006, 09:32
  5. Street art
    By Drinky in forum Comedy & Humour
    Last Post: 28th February 2006, 21:08
vectra c rear coilover setup
how to setup fk coilovers
