Results 1 to 10 of 17
Thread: Rear tyre- inside edge is stepped and uneven?
    Regular Member Craig1985's Avatar
    harwich essex
    Default Rear tyre- inside edge is stepped and uneven?
    The tread on the rear of my bridgestone tyre has become stepped and lumpy?? What is the cause for this? Faulty shocks?
    They started to drone so went to change them to the front and noticed it. Pics wouldn't show it clearly but as you run your hand over it you can feel the steps?
    08 Sri xp2 27k with IDS
    How long have those rear tyres been on the rear?
    Scalloping, as it is known, is almost always due to a failed shock absorber but you should be able to notice this before the tyre wear appears
    It should start as a banging noise coming from the rear of the car
    Once the shock itself fails a collection of liquid should be clearly visible at the base and may even drip on to the road surface (noticeable when leaving the car for several hours)
    You should also be able confirm which side by lifting the rear of the car at the wheel arch, which will result in a squeeking noise
    harwich essex
    Not noticed any liquid, banging or squeezing? Plus car has only done 27k and been in for a service. Surprise they didn't noticed the tyre. They only noted it was more warn in inside edge.
    Will try have a better look at the shock Tomoz then for evidence of leaking under the shock cover
    harwich essex
    Tyres doesn't look original as the other side has a lot less tread. Guessing it's done 10k?
    4 years / 27K miles, and a failed rear suspension component
    Quite shockingly poor really
    Equally, as the car is under 6 years old (assuming you purchased the car in England or Wales, otherwise 5 years) you have a good case for these failed parts to be replaced at VX expense
    The service simply reports on observations, not the cause unless obvious
    If your car is under warranty, then report the matter further
    If not, then have the entire rear suspension fully examined
    On completion have the full four wheel alignment carried out *Hunters equipment
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Its getting more common, I first noticed a lot of Pirelli tyres doing (I work for a Volvo specialist and a lot come with Pirelli as standard) only on the rear of cars, initially after noticing it on more and more cars we thought it was down to the actual tyre distorting but were finding a lot more brands of tyres doing it, we've never (as a company) really looked into the reason why so many tyres are doing it but personally I think it's down to speed bumps, not all of them only the individual lane ones, as they tend to be just too wide to drive over them without touching the wheels on the edges and I thing the angles it's pushing the tyres I think is causing rear bushes to stretch/distort causing the rear alignment to get thrown out far to easily
    Quote Originally Posted by Mr Owens View Post
    Its getting more common, I first noticed a lot of Pirelli tyres doing only on the rear of cars
    As discussed previously, I set one set of my Good Year tyres away for inspection, and their report came back advising it was due to factory settings of the camber which they had found to be incorrect and duly reported to VX
    This suggested the Vectra C with Sports Suspension (to UK specification) were leaving the factory with the standard settings (for EU specification)
    Since I had mine adjusted (to UK specification) I did not have any issue with an identical set of tyres and no adjustment has been necessary for nearly four years now
    harwich essex
    Just found out nissan 350z suffer this with the pe040 bridgestones.
    Car is still under network q warranty do will pop past and ask their opinion.they have been quite good in the past with warranty claims
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    I've just noticed I've got this just checked and shocks fine and so do the bushes seem too wondering if something was done before I had it and it wasn't realigned afterwards
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    I would have said its your rear upper arm outer bushes. I replaced mine for this very same reason about a month ago
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
  1. uneven and serrated rear tyre wear
    By veclee in forum Suspension, Wheels & Brakes
    Last Post: 3rd December 2012, 02:28
  2. Strange uneven rear tyre wear!!
    By maximus8425 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd October 2011, 09:40
  3. uneven tyre wear on rear
    By croado in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2011, 19:12
  4. wear in inside edge of rear tyres
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2010, 23:45
  5. rear tires destroyed on inside edge
    By MRS Wez in forum Suspension, Wheels & Brakes
    Last Post: 17th June 2010, 19:09
