Results 1 to 10 of 19
Thread: temp gauge up n down
    Banned for Being a Numpty
    Jun 2012
    Default temp gauge up n down
    one min its normal then cold doesent go over half much car runs mint,faulty sensor? im new to vecs so lil help be great...cheers
    Engine : 1.9 CDTi
    If its a diesel its probably the thermostat as its a common problem
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Change thermostat
    Jun 2012
    but is it ok still to drive? its not over heating, cheers for replys
    Jan 2012
    Silverstone village
    Yes you can drive it , longer term its not good as the car will never warm up leading to increased wear.
    Mpg may drop about 5-10%
    Well worth doing thermostats can be bought on ensuite for the cdti for around £40, although can be a pain on the 1.9 (120)
    Jun 2012
    i got the 150 2006 aint got a clue where it is
    Engine : 1.9 CDTi
    Have a look in the guides section
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 128000
    its your thermostat its faulty
    as mentioned above this uses more fuel
    buy a original thermostat from vauxhall as well
    the classic sign of a faulty temperature gauge is
    it sits at 0 for ages, moves up to 80 then drops back to 0 again
    diesel} takes around 6 miles to get to 86 -87 and the needle stays there
    { petrol} takes around 3 miles to get to 87-89 and the needle stays there
    depending on weather and speed doing
    if you turn your heater on and the needle falls back to 70 to 75 its broke
    Jun 2012
    My cold heater is warmish is this why? Also had a blown brake light but it wont work and bulbs fine do I need the fault cleared 1st? Any help cheers
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 128000
    Quote Originally Posted by vectraross View Post
    when you replace the thermostat the heater gets hotter in the cabin
    ref the bulb clean the contacts
  1. temp gauge on 1.8
    By MID LIFE CRISIS in forum Engine & Drivetrain
    Last Post: 14th January 2010, 22:10
  2. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  3. Outside temp gauge
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2008, 20:47
  4. temp gauge
    By cow monkey in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2007, 16:22
vectra temp gauge going up and down
vectra 1.9 cdti temp gauge going up and down
vectra c temp gauge up down
