Thread: Clocks change
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    Default Clocks change
    The small display on my rev counter dosnt work ATM its the one that displays the icons for faults
    Its a 1.9cdti 150 2005 model
    Would these clocks fit? They are from a 2.2 dti
    Ebay item number 320847891721
    Jul 2012
    Scottish borders
    Just found some cdti clocks from a 06 car will these fit straight into my 54 plate
    Jan 2012
    Silverstone village
    about halfway through 2004 the cars went from half canbus to full can bus , so make sure you get the correct one.
    Do you have a 3 of 4 spoke steering wheel?
    I think;
    4 spoke = half canbus
    3 spoke = full canbus
    however I maybe wrong , ask the seller what the donor car had.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Scrollers on steering wheel is full canbus.
    Buttons on steering wheel is half canbus.
    HTH
    ---Sent from my iPhone 4 using Forum Runner.
    Jul 2012
    Scottish borders
    My steering wheel has buttons and scrollers
    Scroller is for the volume and menu movement
    So does that mean facelift clocks will fit as long as thier diesel and have the small window under the rv counter?
    Also mines was registered in December 2004
    Jul 2012
    Scottish borders
    It has a 4 spoke steering wheel though
    Full Member Robsey's Avatar
    North East Cheshire
    20 Post(s)
    Trim : Energy
    Mileage : 131,000
    It doesn't matter whether it has 3 or 4 spokes.
    I have a late March 2005 Full CAN Pre-facelift Vectra with a four spoke steering wheel and retro-fitted scroller controls.
    As you have scrollers with your buttons, then you have a Full CAN set-up. And December 2004 means a very early Full CAN Pre-facelift vehicle.
    You can indeed fit the clocks from any October 2004 onward vehicle, however it will need to be programmed into your car.
    ALL modules in the vectra need to be programmed in with Tech 2 or Vauxcom.
    Hopefully the instrument panel will be in a divorced state, otherwise you would need the donor vehicle's car pass number to access it for prgramming.
    Jul 2012
    Scottish borders
    Can they be programmed with opcom?
    North East Cheshire
    20 Post(s)
    Trim : Energy
    Mileage : 131,000
    Opcom is the euro-version of Vauxcom, so yes it is possible with this device.
    PS - be aware that Opcom is not openly discussed on this forum, as any support is available from Ilexa, Auto3m and Opcom.hu.
    There are also other independent forums for the discussion of this device.
    By the way - Just to totally confuse matters - it is also possible to retro fit a full CAN set-up into a half CAN vehicle.
    This is quite involved, but do-able.
    I regularly give advice and information on this particular upgrade / modification.
  1. 140mph Clocks To 170mph Clocks
    By Lean6 in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2012, 20:48
  2. Clocks change- Silly question ?
    By Humph Backbridge in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2008, 18:15
  3. When do the clocks change?
    By wardy in forum General Chat
    Last Post: 30th March 2008, 13:01
