Results 1 to 10 of 19
Thread: 1.9cdti 150 not starting after alternator belt snapped
    Jun 2012
    South Wales
    Default 1.9cdti 150 not starting after alternator belt snapped
    Now i know this is a vectra forum, but my mates got a astra sri with the 1.9cdti 150 engine in it. Couple of days ago it lost coolant which turned out to be the waterpump which i replaced for him. Car drove and ran well for about 100 odd miles, then the alternator belt give up and snapped.
    Had the car towed home with lights on for about 40 miles or so then parked outside the house.
    Fitted a new belt and idler pulley and tried to start it, but it wouldnt go. Tried a different battery and on a bump and jump, but it just wont start. It cranked over but sounded asif it's out of fuel, but got half a tank in it.
    Today i go back and try to start it, but all i get is just clicking from the starter with the ignition lights going on and off whilst trying to start it.
    So one day it sounds asif it's out of derv, then the next it sounds asif the starters knackerd.
    Abit lost to why it wont start from a alternator belt giving up?
    Any ideas chaps?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Sorry for asking but you did set the timing correctly on the belt when you did the pump?
    Clicking could be the starter but could be compression lock too if you have sucked up water or have liquid in the inlet. Way to check this is to remove and refit the glow plugs. That will remove compression in the inlet should it be there.
    Worth checking that the cambelt is all ok too.
    Once belt is checked - try turning the engine by hand from the crank pulley.
    Jun 2012
    South Wales
    I marked the timing at the cam at around 1 0'clock, and refitted exectly how i removed it. Turned it over a few times and it looked good. Sterted straight up and drove fine so i guess it must have been tidy to drive and run. Although i did check earlier and with the groves at the crank lined up, the cam mark is around 3 o'clock :/
    I was tempted to line it up at the crank around 25 past? then remove the belt, turn the cam to 1 o'clock and refit the belt? But thought that may **** it right up? Or would that be in my interest to try?
    It's a 'mates' car so wana get it right. If it was mine i'd burn it,lol.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by Tongon06 View Post
    So with the crank pulley lined up with the marker on the grove on the outer case (about 25past ish) the cam pulley must be at the 1oclock ish mark. If its at 3oclock the timing is way out mate... The only other way that it may not line up to 1oclock is if it's 180degrees out at 25too ish and you just need to turn the crank one revolution again.
    Something has moved for sure then or the belt was not tensioned correctly. Did you use a gm kit where the belt has yellow timing marks? That way you know you are on the correct teeth etc when you install the new belt.
    You need to reset the belt to the correct timing and use only a gm belt with markers. I worry however that it may have bent rockers etc
    Nov 2010
    East Midlands
    Trim : design
    When the belt broke was it a clean break or did it shred the belt - a mate of mine had one shred into boot laces which got wrapped around the timing belt crankshaft pulley and damaged the cambelt throwing it out a couple of teeth with similar problems to yours.
    Jun 2012
    South Wales
    I thought it maybe 180 out, so turned it abit more, but they wont line up.
    He reckons he was doing around 3mph, pulling into a car park and it just cut out. Didnt try to start it, just popped the bonnet and noticed the belt had snapped. Towed it home and fitted a new one, now it wont start. Yesterday it was turning over great, sounded good but asif it was out of derv. It came really close to starting a few times, just couldnt manage it.
    But today, it's like a different engine.
    The belt turned into shoe laces, and had one small strand around the timing belts tensioner, but that came off easy.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Sorry mate. So are u saying the alternator belt snapped or the cam/timing belt?
    Eitherway the timing of the engine is out if u are lining the factory mark on the crank with the grove and the cam pulley factory mark is at 15oclock.
    An alternator belt snap should not cause any starting issues.
    Jun 2012
    South Wales
    The alternator belt snapped.
    That's why i'm stumped as to why it wont start. Had a number of alternator belts snap over the years and never had a problem starting them.
    So you think it's best to retime it at 1 o'clock at the cam and 25 past at the crank and see what happens?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    what is the cars mileage on?
    Middlesex
    Trim : SRI
    Mileage : 100k
    Defo need to set the timing correct mate.
    Was it a gm belt? Did it have yellow markers on the belt?
    Did you mark the correct timing mark on the cam pulley before removing the original belt? If so you have something to line up too, but really suggest you get a gm kit with belt that has set markers.
  1. Snapped aux/drive belt.....
    By scotty84 in forum Vectra C / Signum Troubleshooting
    Last Post: 13th September 2012, 12:36
  2. Tinming belt snapped on 1.9CDTI 8v!
    By benholden2010 in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2012, 21:36
  3. snapped aux belt
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2012, 20:21
  4. alternator belt install.1.9cdti 120
    By Hendry02 in forum Engine & Drivetrain
    Last Post: 17th December 2011, 22:10
  5. Fan belt snapped after 16k?
    By averdigi in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 20:16
vauxhall corsa not starting with alternator belt fitted
vectra duesel alternator belt
how to change auxiliary belt vectra 1.9 cdti
2011 astra Vauxhall alternator belt snapped
vauxhall vectra 1.9 cdti alternator belt
vauxhall vectra sri cdti 150 wont start after new timing belt
vectra c fan belt snap
vauxhall vivaro new timing belt wont start
vectra cdti broken rockers
changing aux belt on astra cdti 1.9 2008
alternator belt snapped while driving on vauxhall zafira
opel corsa not starting after changing fan belt
vauxhall vivaro van wont start after fan belt broke
insingia timing belt broke
auxillary drive belt snapped vauxhall vectra
vectra alternator belt broken
vectra 99fan belt snapped
vauhall insignia broken rockers and missing teeth off cambelt
astra h 1.9 cdti cambelt snapped and now engine wont start
opel vectra c 1.9 auxiliary belt
