Thread: Noisy blower fan
    Regular Member ads3's Avatar
    Northants
    Engine : 2.0 DTI
    Mileage : 86,000
    Default Noisy blower fan
    How on earth do you describe a noise?
    My blower fan works fine apart from sometimes it sounds as though it's loose or a slight rattling, sometimes a slight 'chirping' sound. Hopefully you get the idea.
    Anyway does this mean it's on it's way out?
    If so am I best going to a scrappy and getting one as I should imagine they're pricey (after a new diesel pump, turbo, egr valve etc. etc. anything above a fiver is now pricey).
    And lastly how easy for a complete novice to remove and replace?
    All suggestions advice greatly appreciated.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    take the pollen filter out and turn it by hand. if its stiff and starting to seize you'll blow the resistor. you could try spraying wd40 on it but it sounds like the bearings are worn.
    Northants
    Engine : 2.0 DTI
    Mileage : 86,000
    I wondered if it's the bearings. I thought access to this was from under the glove box?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    You'll need a new blower motor mate. Check your skuttle tray too for water.
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Quote Originally Posted by ads3 View Post
    yes you remove/replace by the 7 torque screws and the fan slides out under the glove box. but if you take the pollen filter out you can turn the fan by hand and see its stiff and spray wd40 on it. also check the scuttle isn't blocked while your their.
  1. noisy cat
    By vectrabtcc in forum Engine & Drivetrain
    Last Post: 15th February 2012, 10:51
  2. Noisy Air con
    By chief29 in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2009, 19:19
  3. Noisy A/C
    By multi in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2008, 20:03
  4. noisy air con
    By John35 in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2007, 14:14
  5. Noisy car help please
    By Higgins in forum Engine & Drivetrain
    Last Post: 28th February 2006, 22:27
noisey blower fan vauxhall vectra
