Results 1 to 10 of 18
Thread: How do i decat my car???
    Regular Member Vectra Adz's Avatar
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Default How do i decat my car???
    As above.. I want to take the cat of my car... whats the easiest way to do this?? how would i smash it out as such???
    Also... Mines a 04 hatch... 1.9 cdti 120... do i have a precat??? and a normal cat.. i know i defo dont have DPF...
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Precat is at the front of the exhaust coming off the manifold/turbo. You can remove it and knock the stuffing out of it making sure you remove the sensor first so it does not get damaged or replace it with a pre cat pipe. You can replace the main cat under the car with a straight through pipe,there are no sensors going into this one
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    i brought a second hand pre-cat and used a hammer, mini chisel, and drill to smash the insides out. and my mate who is a mechanic fitted it. and then cut the main cat in half and smashed the internals out and welded it back up.
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    cool i hope its as easy as you say lol.
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    if you get a custom strait through exhaust you would only need the pre-cat doing.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    £120 for that little bit of pipe its ridiculous. thats why i just smashed mine out its a lot cheaper.
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    to be fair, that does seem a bit much for a piece of pipework, i might look for a 2nd hand one, and do that...
    this one will do wont it?
    http://www.ebay.co.uk/sch/i.html?_tr...recat&_sacat=0
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    Mate you can get decat pipes brand new on ebay for 69 quid i believe
    May 2011
    Type in vectra c decat pipe
  1. 2.0 dti decat help?
    By kieronlee in forum Diesel Engine related
    Last Post: 2nd April 2011, 19:54
  2. 2.0 dti decat
    Last Post: 28th March 2011, 10:21
  3. decat 2.2 sri?
    By davaroo in forum Petrol Engine related
    Last Post: 17th March 2011, 19:48
  4. to decat or not to decat a gsi - is it worth it?
    By TimTay in forum Petrol Engine related
    Last Post: 21st January 2011, 21:25
  5. 3.2 V6 GSI Decat.... Is this ok??
    By VinnyPeewee in forum Petrol Engine related
    Last Post: 26th November 2007, 22:01
