Thread: map sensor
    Apr 2012
    reading
    Default map sensor
    Hi, I have a cdti 150 auto 2007, engine light on code reads map sensor, is this the same as boost sensor? I cleaned boost sensor but light still on, will be a case of new one needed thanks Andy
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Have you cleaned it then cleared the code? If you havent cleared it, it may stay on for a few starts.
    Apr 2012
    reading
    Not tried to reclear yet, it wouldn't reset when it was bein read is that normal?
    Jan 2012
    Milton keynes
    Mileage : 38100
    So, with the engine off, just key in the ignition to first click and reader plugged in... you cant clear the fault?
    As far as I'm aware, I thought it would at least clear but then if the fault was still present immediately pop up again? Is the sensor plugged in and seated properly?
    What code reader are you using?
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    What type of diagnostics are you trying to use? Are you telling it correct year engine etc?
    Apr 2012
    reading
    Don't no what comp it is going to go back tomorrow, but no would not go out, normally you can reset a fault code but this didn't even flicker,
    Apr 2012
    reading
    Code reads p1100
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
