Results 1 to 10 of 28
Thread: smoke / lumpy when first tuned on at cold
    Jun 2011
    kent
    Default smoke / lumpy when first tuned on at cold
    hello all
    wondering if you can help
    i have a 1.9 cdti (150) when i start it for the first time in the morning or after work it starts first time but i nearly always get a bit of a cloud of white/grey smoke like an old petrol car and the engine feels lumpy or guddery. anyone know what could be causing this?
    im thinking of changeing the oil this weekend, so while i have it up is there anything i shuld do or look out for.
    swirl bar has had the mod done and moves incase you was thinking that
    cheers
    Aug 2010
    Leeds
    A faulty glow plug or a leaking injector.
    Test the plugs for a start & you can just replace the faulty one if you wish id replace all 4x.
    Regular Member bigdave1701's Avatar
    York
    I had this problem. had diagnostics run twice but found nothing, replaced the glow plugs twice but no change. In the end I took it to a diesel specialists who instantly diagnosed it as a goosed Dual Mass Flywheel £900 later it was running perfectly again.
    Jun 2011
    kent
    the DMF and clutch were changed about 30,000k ago, brand new parts too. £1600 at a main dealer. this sholdnt have gone already. the car doesnt judder or take off bad. how much am i looking at for glow plugs?
    would it help if i said that when i floor it at abot 3-4K theres a fair amount of smoke, but you can only really see it at night when there are lights behind yo
    Aug 2010
    Leeds
    When was it last serviced?
    A new fuel filter and air filter should cut out most smoke, but if this persists you will need to investigate further, check turbo oil seal's & intercooler for excess oil.
    Regular Member Sierra2's Avatar
    Sep 2010
    London
    Trim : SRI
    Engine : 1.9cdti (120)
    Mileage : 45k
    By leaking injector do you mean `the leak off pipe(s)` ?
    Quote Originally Posted by Bigtee View Post
    Jun 2011
    kent
    it was serviced a while ago, compared to the miles, was thinking of doing the service myself next week, any recommendations on what i should look out for, its just done 100K, litterally today 100,001
    Aug 2010
    Leeds
    Quote Originally Posted by Sierra2 View Post
    No i mean a dripping injector.
    Op says lots of smoke on start up and judders like missing.
    Aug 2010
    Leeds
    Quote Originally Posted by webtrawler View Post
    The fuel filter is a must so is the air filter & good oil and filter just for starters, have you checked the glow plugs yet? better to take them out see how well they glow no more than 4 seconds across a battery or they melt.
    Jun 2011
    kent
    apparently you can check these using a multimeter, is this easier? as i havent had time to look at the car yet
  1. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  2. CDTI lumpy idle & smoke?
    By bigdave1701 in forum Engine & Drivetrain
    Last Post: 17th September 2012, 13:48
  3. smoke, loss of power, lumpy, cut out, help please.
    By GrannySmiff in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 07:06
  4. Very lumpy cold and warm startup and grey smoke
    By cheekylemon in forum Engine & Drivetrain
    Last Post: 5th July 2011, 22:33
  5. 3.0 cdti lumpy when cold pos tunned?
    By chris5360 in forum Diesel Engine related
    Last Post: 25th July 2010, 21:53
