Results 1 to 10 of 17
Thread: Brake fluid bleeding
    swansea
    Default Brake fluid bleeding
    Changing a rear caliper, any suggestions on bleeding the fluid, will probably bleed all so that the fluid is renewed.
    Regular Member MattVecVXR's Avatar
    Mar 2012
    Torpoint, Cornwall
    Trim : VXR
    Engine : 2.8 V6 Turbo (280)
    Mileage : 82000
    Use a vizibleed with two people, although it can be done with one person, you'll get better results with two.. Start at whichever caliper you like, pump up the pedal til its hard, open the nipple until the pedal reaches the floor, shut the nipple and lift the brake pedal. repeat until no air comes out. keep the header tank topped up and don't let it empty. worth doing the whole lot, just make sure you use a compatible brake fluid... dot 4 or dot 5.1.
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    I think its recommended to start at the caliper furthest from the header tank and move around the car finishing at the caliper closest.
    I'd only use what fluid has been used before, it should say on the header cap. Anything else and you should replace all seals through the braking system.
    Aug 2010
    Leeds
    Gravity bleed.
    Clamp the flexi remove the caliper & refit the new one, open the bleed nipple put a dish under the caliper, go make a coffee come back fluid should be dripping nicely from that caliper nipple. Top up resovoir afterwards. job done.
    Quote Originally Posted by Chunklamb View Post
    so everytime you bleed the brakes you should remove every item of the system ( 4 calipers and master cylinder ) and replace all the seals
    dont know who told you this but its utter rubbish
    Regular Member Keif's Avatar
    In the Garage
    Buy yourself an EasiBleed kit (can get it from Halfords) Use your spare tyre (at 14PSI) to pressurize it.
    Ideally you want the car on axle stands and ALL four wheels of the car.
    Get a syringe and remove as much brake fluid from your master cylinder as you can. Then fill with new Brake Fluid.
    Then screw on the easibleed and pressurize the brake system.
    Starting from the furthest from the master cyllinder (nearside rear wheel) undo the bleed nipple until new fluid is visible (without bubbles) in the clear pipe. Do up the bleed nipple.
    Check your brake fluid reservoir and top up and repeat for the offside rear, nearside front and lastly offside front.
    Check for any leaks and full the reservoir up to the max level.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Quote Originally Posted by marktaylor View Post
    am with mark what alod on poooooo
    Mar 2012
    Torpoint, Cornwall
    Trim : VXR
    Mileage : 82000
    I wouldnt bother buying a eazibleed unless you plan on bleeding brakes often. its easy to use but for the expense and having to dig out the spare wheel, the vizibleed achieves the same results at a fraction of the cost and is still very easy to use.
    Quote Originally Posted by Bigtee View Post
    Gravity bleed.
    I would not drive a car without confirming all the air is out of the system. By removing the hose, you are allowing air to travel up the system, all it takes is a bend to cause an air lock. for the sake of pressing the brake pedal a couple of times, its not worth risking.
    It doesn't matter what order you bleed the calipers on modern cars, the abs block negates this requirement. also you can change the brake fluid as long as it's compatible. if you're changing from dot 4 to dot 5.1 you need to bleed the whole system and carry out a full fluid change. if you're just topping up, then use the same fluid.
    Agreed, the only seals you should be renewing is the aluminium crushing washers on the banjo connection for any calipers that have been removed... and the caliper seals if needed.
    In the Garage
    Quote Originally Posted by CDTiMatt View Post
    I drop the pressure in my offsdie front wheel and use that. Then pump it up to pressure when finished.
    swansea
    Thanks all.
  1. brake bleeding
    By Al 22 dti in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2012, 17:33
  2. Brake bleeding..
    By macdad in forum General Motoring Chat
    Last Post: 10th July 2012, 07:30
  3. Having trouble bleeding clutch fluid? Read this!
    By bobmoss in forum Suspension, Wheels & Brakes
    Last Post: 15th May 2011, 20:11
  4. Draper Brake Bleeding Kit - Anyone used it?
    Last Post: 16th December 2010, 20:33
vectra c brake bleeding nipple
vectra c bleeding brakes
Bleeding the brakes opel vectra
