Thread: Aircon problems - Not working, if anything air gets hotter turning on aircon???
    Regular Member Coupe2T's Avatar
    May 2011
    Hampshire
    Question Aircon problems - Not working, if anything air gets hotter turning on aircon???
    As title really, We finally have some nice weather, so I thought i'd get the aircon on only to find out it's not working.
    I have owned the car for about a year, but never really used it much before, So may just be out of gas, but before I go and get it re-gassed etc I wanted to check if there is anything else I should be looking at first?
    As said in the title, if anything the air gets hotter when I turn the aircon on, although this could be in my head as it only feels marginal difference. May just be me worrying about it.
    Anyone any ideas? Any known issues with aircon etc that can be checked easily?
    Regular Member ads3's Avatar
    Northants
    Engine : 2.0 DTI
    Mileage : 86,000
    Can't offer a solution as mine is the same, I'm just searching for advice now.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Should use at least once a week to stop seals from drying out. It needs to be tested with UV dye to check for leaks. If your lucky just a regas if not could be
    new condenser as these are prone to stone chips through bumper some people have put wire mesh on bumper to stop this
    New Member SamArt's Avatar
    Jul 2012
    Derby
    Trim : Exclusiv
    Engine : 1.8
    Mileage : 42500
    My air-con on my car is the same. I recently had a regas and had a service recently where my pollen filter was changed.
    May 2011
    Hampshire
    Quote Originally Posted by SamArt View Post
    You had it re-gassed and it still doesn't work?
    That's what I am worried is going to happen.
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Any place offering a re-gas service should do a proper pressure test before hand, if it fails this most likely they wont charge you. As troutybrown says Aircon should be run often, even during the winter, to stop the seals dying out. IIRC the manual says once a month for about 20 mins. Are you hearing the compressor cut in when you push the button? If it is working ok the engine revs will die slightly as it cuts in. Seen quite a few people have issues with a failed compressor clutch.
    May 2011
    Hampshire
    I will have to test tonight and see if I can hear them drop. Thanks for the info, I will let you know.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    That's interesting. Slikkers regassed mine, along with others, last year. Worked fine for a few weeks, then just went cool instead of cold, now doesn't work at all. They did indeed pressure and dye test it, all was fine. Not noticed any clicks or drop in revs, was wondering if something else had failed. Been meaning to get it back over to him, but with Wendy having so much time in/out of hospital since December , then me having surgery on both eyes never quite got around to it.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    Quote Originally Posted by Grumpy1954 View Post
    its not a good sign if its been re- gassed
    and it still has problems
    as member golden wonder has found out
    http://www.vectra-c.com/forum/showth...t=goldenwonder
    Sep 2010
    My other SRI has this very problem, been with the dealers many times (as originally reported in 2010 under warranty and again in last month of the MW) went in Friday, dye test revealed small leak in condenser. Ran a sealant through it and lost gas within 48 hours.. so now I have to go back again. Wouldn't mind but it's the time expenditure on my part - 2 hours lost per day. Now going again for a 7th visit, thats 14 hours!!
  1. Is my aircon working???
    By Vectra Adz in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2012, 22:07
  2. Blowers not working on any setting. Climatecontrol/aircon
    By Chuddy in forum Vectra C / Signum Troubleshooting
    Last Post: 9th December 2011, 18:40
  3. Aircon regassed week ago now not working?? :(
    By dawn78 in forum Engine & Drivetrain
    Last Post: 1st August 2011, 16:39
  4. Aircon problems
    By Steevo in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2011, 23:59
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
