Results 1 to 10 of 13
Thread: CDTi-150 Flat Spot @ 1800rpm
    Jul 2009
    Yorkshire
    confused CDTi-150 Flat Spot @ 1800rpm
    My 57-plate Signum CDTi-150 has developed a flat spot around 1500-1800rpm. It's lasts approx half a second then it drives perfectly. The car has done 31k miles with fsh.
    I've read threads on here regarding the flat-spot being a known common problem on the CDTi's. I've checked the swirl bar and that's fully attached and fine. I've checked the injector wiring and the car already has the factory-fit blue multiplugs (opposed to the yellow ones). I've checked the vacuum hoses and they're all in good condition with no splits. I've changed the fuel filter and regularly check the fuel filter housing tap for water but that's fine. The DPF does its regen approx every 600miles without issue, and I've cleaned the EGR (but not the EGR solenoid). I've got no engine management lights or warnings, and I'm not noticing any loss of mpg etc.
    My next plan is to disconnect the EGR lead and take it for a spin - see what happens etc. Any ideas what else I could do?? Thanks.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    have a read of this
    sorry if you have allready this may help
    http://www.vectra-c.com/forum/showth...ght=hesitation
    Jul 2009
    Yorkshire
    Thanks mate - I'll have a read through the link...
    Jul 2009
    Yorkshire
    rolleyes Have I solved my own problem??
    I think I might have answered my own question here! I've just taken the car for a quick spin and it was still hesitant with the usual flat spot around 1500-1800rpm. I then disconnected the EGR multiplug lead and took it for another spin. It seems to have solved the flat-spot problem which would suggest that the EGR and/or solenoid is FUBAR'd. I was expecting the engine management light to come on when the EGR was unplugged, but it didn't. Does that mean I can continue driving without the EGR being plugged in until I get a new EGR in the next few days, or will it cause further problems?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 137000
    give the egr valve a clean and the solenoid just before you buy one mate save 100 pounds
    whats your mileage on ?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 137000
    West
    Quote Originally Posted by Signum7060 View Post
    I drive with egr unplugged all the time & only plug it back in for the mot
    Jul 2009
    Yorkshire
    Quote Originally Posted by vectra ste View Post
    It's only got 31k with full service history etc
    Jul 2009
    Yorkshire
    Doesn't that cause any damage (ie to the DPF etc) or cause the engine management light to come on?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    I think it does eventually, but only if you have a DPF fitted, vec c Estates or Signums only...
  1. CDTI 150 Dreaded flat spot HELP!!!
    By keets in forum Engine & Drivetrain
    Last Post: 19th October 2015, 09:26
  2. Flat spot on CDTI 150-how many suffer from this-*POLL*
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 22nd January 2013, 07:51
  3. Could this be the cause of 1.9 cdti 150 flat spot?
    By andreitone in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 18:00
  4. Hesitiation/flat spot 2007 V6 CDTi
    By Penfold101 in forum Engine & Drivetrain
    Last Post: 13th July 2011, 18:27
  5. CDTI 150, more FLAT SPOT HELP please!
    Last Post: 7th May 2010, 23:28
vectra c flat spot 1800rpm
