Thread: Diagnosing suspension knock
    Jun 2011
    brum
    Default Diagnosing suspension knock
    I get a knock from what i think is the front drivers side everytime i go over pot holes, speed bumps or just really bad roads. I'm assuming its going to be one of three things:
    a) Top strut mount
    b) Drop links
    c) ARB bushes
    How would i go about confirming which one of those it is (if any), preferably the less taking apart of the car as possible as i have to do all my work on a mini factory car park across the road.
    Thanks for any help
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Drop links-With the car on the ground reach behind the front wheel and grab the link rod. Any movement/frre play is bad news.
    ARB Bushes- Jack up the front of the car and look at the mounting bush, if you see any gap at the bottom then replace.
    I would go for these items first as cheapest and easiest to replace.
    Not sure how to check movement in the Top mount
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by tangoman View Post
    They usually make the noise when the steering passes the centre mark, you get a twang/clunk from the offending strut, get someone to turn the steering from side to side while you feel the springs/struts (if you have room to obviously). Cheap part to buy, bit a pain to replace (remove strut etc).
    Jun 2011
    brum
    Well i've been out today, there feels like there's about 1mm play in each droplink, so im assuming they need replacing. and whilst im at it i may as well replace the arb bushes as the passenger side looks pretty bad.
    Some pics of the bushes: http://imgur.com/a/FHU3x
    So uprated droplinks and them powerflex? bushes will need to be ordered this weekend so i can get them replaced next saturday. Looks like i'll have to do some forum searching for the actual names and P/N's i need
    Thanks for the help both
  1. Rear suspension knock
    By RollingStone in forum Suspension, Wheels & Brakes
    Last Post: 6th September 2012, 18:45
  2. front suspension knock
    By starykokot in forum Suspension, Wheels & Brakes
    Last Post: 2nd May 2011, 13:31
  3. Self repairing suspension knock??
    By RLFH470 in forum Suspension, Wheels & Brakes
    Last Post: 29th March 2010, 13:43
  4. Sorry to ask about suspension knock again but...
    By Villers in forum Suspension, Wheels & Brakes
    Last Post: 28th January 2010, 23:53
  5. Front suspension rattle/knock
    By damian s in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2010, 16:47
