Thread: help wiring double din
    Feb 2012
    middlesbrough
    Default help wiring double din
    hey basically ive tried plugging yellow to yellow red to red (it makes the reset sound the lens aligning then powers off) i tried yellow to red/red to yellow = no power at all.. any suggestions on what todo? thanks
    Feb 2012
    middlesbrough
    Quote Originally Posted by bowey View Post
    plz delete this, i took a live feed from the fag lighter and it works perfect.
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Ah - you would be describing a full CAN set-up then. (Quadlock connector)
    Full CAN does not have ignition live - instead it has CAN controlled live.
    Only the half CAN vehicles have a black wire on pin 5 (I think) for ignition live. (ISO connector).
    For those reading this - For Full CAN head-units.
    Aftermarket yellow goes to head-unit loom red
    Aftermarket red goes to cigarette lighter plug black
    Dec 2011
    Seaham
    Wiring is generally very simple, always remember
    Red to Red
    Green to Green
    Blue to Bits
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Aftermarket is different to vauxhall
    As follows: -
    Ignition Live - Vaux = Black, After market = red
    Permanent live- Vaux = red, aftermarket = yellow
    Ground - Vaux = brown, aftermarket = black
    other Vaux colours found in head-units are: -
    Grey/Green, Grey/Black or Grey/Yellow = illumination
    Green = CAN comunications High signal wire - but also see speaker wires below
    White = CAN communications Low signal wire - but also see speaker wires below
    blue/red = calculated road speed signal
    red/white = electric aerial or RF aerial signal amplifier
    speakers are
    yellow and brown/yellow
    white and brown/white
    blue and brown/blue
    green and brown/green
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Apart from the wires colours, live and ignition wires positions are reversed on the ISO connector as compared to standard.
    Half-CAN don't have a real ignition either, it has to be buffered (using transistors for instance), as it doesn't provide enough current to switch on most aftermarket car stereos (nor a Parrot handsfree kit, for instance).
    If you're not buying a specific adaptor loom, you can easily use an NPN transistor and two resistors to switch a 12V relay or just a PNP darlington to provide the necessary signal.
    Another cheap alternative is to use the cigarette lighter +12 (black wire) for the ignition signal. It's very easy to get it from the bottom of the plug, as the connector is actually just made of two ordinary spade connectors : you can find suitable Y derivations anywhere, and it will provide an easy access to a high current and fuse protected contact key switched +12 source for all sorts of uses (gauges, power box, etc.)
    I don't use it for car audio or handfree kit switching, however, because it will switch off as soon as you turn ignition off, while the original radio ignition signal will stay on as long as you keep the key in the ignition switch. This behavior is useful when you want to go on listening to the radio after you turned the car off, but also when talking to someone using the handfree kit...
  1. Eto sat nav double din hu
    By larrygroke in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2012, 21:12
  2. Got the double din in at last!
    By Maddog1974 in forum ICE Gallery
    Last Post: 8th April 2011, 08:59
  3. Double Din
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 25th August 2008, 22:30
  4. double fascia and wiring kit (kenwood)
    By pmw123 in forum Parts for sale
    Last Post: 28th May 2008, 21:21
  5. double din
    By rich32 in forum Electrical & ICE (including SatNav)
    Last Post: 24th February 2007, 18:21
