Results 1 to 10 of 11
Thread: Locking tool for 1.9 CDTI
    Jul 2012
    Ireland
    Default Locking tool for 1.9 CDTI
    Does anyone have this tool for borrowing? I'm down south and looking at prices on ebay, etc. With the exchange rate and delivery these things are coming up to 70euro!!
    The car is a vectra cdti 120bhp. Year 2005
    If i could borrow one (with a small rental fee!!) it'd be great.
    Any comments would be really appreciated.
    Jul 2012
    Ireland
    Has anyone bothered changing their own timing belt??
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    DOne many mate and you dont need a locking tool if your confident etc...
    GM Belt as all the correct timing marks.
    Jul 2012
    Ireland
    Thanks AntSSSS. The locking tool would help ease my mind though! The autodata t-belt book says its a 2,10hr job so hopefully not as bad as most.
    Regular Member vectra gsi 3.2's Avatar
    Dec 2011
    vectra -c nutters crew
    6 Post(s)
    Vehicle : gsi
    Trim : quality
    Engine : 3.2
    mines going for a belt change next week, peace of mine then its done.
    Jul 2012
    Ireland
    Buying myself the set in a few weeks and doing the job in about 3 from now. If anyone needs to borrow the locking tools afterwards, just give a shout.
    Jul 2012
    Ireland
    Hi all.....in an emergency here! Made a mess of timing belt change. When I had the locking tool off to take the old belt off Iand I rushed into fitting the new belt. It turned the crankshaft 1/4 of a turn but I don't know if it was anti or clockwise.
    So I'm in trouble!
    There is a small notch on the crankshaft and one on the shoulder. Does anyone know if this is ok to use to line up? This could be used for a rough guide and then the locking tool could be used to get it precise.
    Engine : 1.9 CDTi
    Have a look in the Guides section as I think it shows you.
    I only use those marks and never use the locking tool (Done about 20 now lol)
    Jul 2012
    Ireland
    All done. It was tough going. Whatever could go wrong went wrong!
    In the end I found that the crankshaft had been set at 180 degrees off (before I took off the original belt) which is why the locking tool didn't fit spot on the first time.
    I turned it 180 and the locking tool fit perfect. If I matched the notch on the crankshaft sprocket to the notch on the shoulder I would have out by 90degrees and an engine. I honestly don't know how guys can mark this accurately. It's a small sprocket and leaves a lot of margin for error. I was also worried about the fuel pump sprocket setting but no need as it its common rail.
    Also, the water pump ****ed water when I flooded it! Luckily I tested this before working at putting back on the timing belt.
    A weekend I will never get back! First timing belt change on these, good fun!
    Dec 2011
    6 Post(s)
    Vehicle : gsi
    Trim : quality
    Engine : 3.2
    Quote Originally Posted by sog View Post
    at least u got there in the end, stressfull yes for sure, but sorted and back on the road....
  1. 1.9 cdti 120 - locking tool for timing belt renewal
    By sog in forum Engine & Drivetrain
    Last Post: 17th September 2012, 10:21
  2. Replies: 2
    Last Post: 23rd July 2012, 22:29
  3. 2.0 camshaft locking tool
    By grierson1972 in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2011, 22:14
  4. cam locking tool 2.2
    By veccyv6 in forum Engine & Drivetrain
    Last Post: 7th July 2011, 13:17
1.9 cdti cam locking tool
1.9 cdti locking tool
vauxhall vectra c 1.9 locking tool
