Results 1 to 10 of 13
Thread: Can the vectra start if the battery key is dead?
    Regular Member danlat1415's Avatar
    Lancashire
    Default Can the vectra start if the battery key is dead?
    Can the vectra key start the engine if the battery in it is dead?
    I've lost my spare key but the battery in it is dead.
    I'm wondering whether to go through the hassle of informing insurers and replacing the locks.
    I think I remember using it previously and it setting the alarm off, but unlocking the door (when physically put in door key slot).
    I'm wondering if the electronics in the key, with the battery being dead - won't turn off the alarm or start the car due to not being able to turn off the imobiliser
    I never keep valuable in the car anyway, so just wondering for peace of mind that someone can't drive it away (they may be able to release hand brake and tow away, but not fully drive the car).
    Regular Member Adam8220's Avatar
    Apr 2011
    Ripley, Derbyshire
    Im almost certain the car wont start if the imobiliser has been activated. There may be a signal for the transponder ring though for the guts of the key to deactivate this when in the ignition.
    If in doubt tech 2 the key out of the system and just have you r main key programmed in. The spare will still be physically able to unlock the car and fit the ignition but the transpondr will not be listed in the ecu as a recognised key.
    Barrow In Furness, Cumbria
    I think it will start the car. I reckon as well that if you put the key in the ignition and turn as if to start it then the alarm will stop.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    If they can work out whos car it belongs to im sure they can change a battery. But yes the car will still start anyway
    11 Post(s)
    Quote Originally Posted by danlat1415 View Post
    The battery inside the fob is only for the central locking.
    If anyone finds it and manually unlocks the car with it, yes the alarm will sound, but as soon as they put the key in the ignition it will silence the alarm and they'll be able to start the car.
    The immobiliser chip in the fob is powered by an inductance loop fitted to the key lock or steering column.
    Wondering lonely as a cloud
    25 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    But bear in mind if the spare has been away from the car for a long period mine was over a year then the immobiliser in the CIM won't recognise them mine had to be reprogrammed to the CIM a quick job but it needed Tech 2
    11 Post(s)
    Quote Originally Posted by paulhb View Post
    I've had my Vec for 5 years now. Spare key has been in the drawer all this time. Tried it the other day - worked fine. Even unlocked the doors with the fob buttons - I thought at the very least it might have needed re-syncing to the central locking. Dash lights were set to a different illumination level and the climate control was at a different temperature to what I normally set it to, along with the CC being in eco mode. I only recently realised each separate key can remember certain separate settings.
    25 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    I have 2 spare keys since I updated to a flip one and they have been in the drawer for just over a year went to use them as a test a couple of weeks ago and no central locking and a big padlock on the dash display when I tried to start the car with them, got a mate to pop over with Tech 2 and 2 minutes later both were able to do everything again tried them just now to check and they are happy still
    Feb 2011
    Selby
    According to the Owner's handbook, you can deactivate the alarm by either pressing the 'unlock' button on the key, or putting the key in the driver's door lock, turning it towards the front of the car and then back to vertical. The transponder chip is only for the immobiliser on the ignition switch. You can set the alarm by putting the key in the door and turning it to the rear of the car, then back to vertical, then to the rear again, then vertical and remove. In other words - exactly the same as pressing the 'lock' button twice as normal to set the alarm and deadlock the doors.
    So if the battery is flat in the key, you can still set and unset the alarm and start the car.
    Full Member
    Mar 2011
    n. ireland
    when i bought the vectra the mechanic said to always rotate the use of the keys (2 of the said keys ) so i use a set and my wife uses the other set, the reason is because he said that lack of use and the car would not recognise the key and then would not start the car
  1. Dead battery ?
    By Scoobycarl in forum Engine & Drivetrain
    Last Post: 27th July 2012, 12:05
  2. Cars dead. Won't start. Fan runs when it would start.
    By baz_rochdale in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 22:34
  3. Vectra C can't start after battery removal
    By tomek80 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th June 2009, 19:22
  4. Dead battery
    By Morephun in forum Engine & Drivetrain
    Last Post: 23rd November 2008, 13:48
  5. Dead Battery
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2006, 12:35
vectra c key fob battery
vauxhall vectra totally dead battery
dead for Opel vectra c
how to replace vectra c battery fob
does low battery in zafira key fob stop the engine from starting
vauxhall vectra 1.9 cdti key set off alarm
dead battery in key fob insignia
insignia battery flat
vectra c dti car just turns over could it be the key
vectra wont start after flat battery
will my astra start if key fob battery is dead
my opel vectra wont start even though i put new battery in the key
how to start engine with key on a vectra cdti
vectra c flat key battery
opel vectra c 2005 1.9 cdti says key battery low
If the battery is dead on my key fob will this stop my vectra c from starting
driving vauxhall signum when key battery is flat
vectra key dwad battery
vectra key wont start car
