Results 1 to 10 of 17
Thread: New warning light!
    Mar 2012
    Hampshire
    Default New warning light!
    Hi guys, got in my poorly misfiring vectra this morning and noticed this warning light. I have no idea what it is, any ideas?
    Just wondered if it had anything to do with my single cylider misfire as new plugs didnt sort it, new coil pack is on the way and will be fitted next week anyway.
    Tom
    Dec 2011
    Seaham
    I would say low water level?
    Mar 2012
    Hampshire
    Quote Originally Posted by Ben50n View Post
    Thanks but is that a random guess?
    Even still I will check.
    Dec 2011
    Seaham
    Yep random guess, it looks like a picture of a radiator.
    Barrow In Furness, Cumbria
    Low coolant level.
    Fingers crossed its not the head gasket if its misfiring and loosing coolant....
    Mar 2012
    Hampshire
    Quote Originally Posted by Chris SRi View Post
    Certainly hope not!
    I havnt checked coolant for a while and its been hot. Besides, the misfire problem I have is almost certainly a bad coilpack due to troubleshooting my mechanic has already done.
    Changed the plugs AND swapped the coil from cylinder 5 into 6. The misfiring has calmed down loads now but is still there when its given the beans, I have a new coil on the way.
    Mar 2012
    Hampshire
    By the way, the light isnt on all the time, noticed it yesterday morning, turned ignition off, back on, no light. I will check if the light is on when i start the car again in a minute.
    Regular Member Keif's Avatar
    In the Garage
    So you coolant is right at the bottom limit for the warning light to come on.
    Before starting it up again, top up the coolant level as the warning light is telling you it's low.
    Mar 2012
    Hampshire
    Just went out to start the car, light isn't on this time. Still I will check the coolant at lunch.
  1. Warning Light
    By chrissy white85 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
