Thread: Help please needed with my 1.9cdti Christmas tree dash
    Jul 2012
    United Kingdom
    confused Help please needed with my 1.9cdti Christmas tree dash
    hello there
    i have recently purchased a 2004 (54) vectra 1.9cdti its got 115k with fsh
    i bought the car on the 21st (saturday) by sunday night it was in the crawler lane of the motorway no passing 3,000rpm
    since then the light (car with a spanner through) is my new best friend and keeps coming on
    in a morning 2 clicks of the key brings the light up witch goes off once the ignition is turned on and does not come back on untill the car has been driven for about 30 minutes i dont notice any performance changes untill i get to the bypass as soon as the car goes 70 80 bam limp mode appears car goes like a snail as soon as i have done 8 miles like that i come off the bypass and the car say setting off at traffic lights leave a fair amount of smoke not loads but enough to see in the mirror and think that doesn't look right upon pulling up i can smell a hot burning smell like burning oil,
    i had my friend plug it in on his machine it came up as "boost pressure voltage" and "throttle voltage"
    i do have my own diagnostics scanner (just a cheep ebay £60 job) but strangely wouldn't read the code "no faults detected"
    its a pain with only owning the car for less than a week and it being like this hoping someone might shine a light for me as from threads i have been reading some of you know your stuff
    before anyone replys saying "use the search" i have searched this 10 other and all of Google before writing this
    hope someone can give me a pointer
    Jul 2012
    United Kingdom
    anyone??? would be great full
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    sounds like the egr valve needs a clean and the boost sensor
    try these first
    http://www.youtube.com/watch?v=_le1s...ure=plpp_video
    need to get rid of all the soot
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    There's a 'HOW 2' for the throttle body repair & clean, DO the repair even if the solder joints look good cos more than likely they'll be naf!, You may also have oil in the circuit board area so its a job worth doing!, Its typical for the throttle body to play up when the engine gets warm & it sounds yours is similar.
    Jul 2012
    United Kingdom
    thanks for the info folks will be sure to get them done as soon at the car comes back from the garage went to start it on Sunday morning and there was nothing not a peep turned out the starter motor had died so had to get a new one fitted witch is a bit of bummer on a car i have owned now for less than 2 weeks
    Jul 2012
    United Kingdom
    just watched both the videos and looks fairly simple one question to "the-wizard" when you say "circuit board area" where is this area please
    Jul 2012
    United Kingdom
    also after cleaning the egr is it worth while blanking it with a platw with a 9mm hole in it? or is it best just to let it do its own thing?
  1. Real XMAS Tree Tips Needed
    By Diet1985 in forum The 'Off Topic' room
    Last Post: 5th December 2009, 19:49
  2. Christmas Tree Size!
    By Batman in forum The 'Off Topic' room
    Last Post: 8th December 2008, 14:11
  3. Finished the Christmas tree
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2007, 00:12
  4. MAYDAY!!!!! Major Help Needed for Christmas
    By Brocks in forum General Chat
    Last Post: 5th December 2006, 12:36
