Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: P1191 - Fuel Pump or Regulator?
    Jun 2012
    Edinburgh
    Default P1191 - Fuel Pump or Regulator?
    Hello!
    It just happend to me today and I am bit scared seeing all the problems with the HP pumps and regulators to the Z22YH engine.
    The car and spanner appeard on the dashboard. The car was still driving fine. I stopped the car and the spanner dissapeard for 5 minutes. Then I stopped again and I couldn't start the car. After a few minutes the car started.
    I checked the codes with OP-COM and:
    P1191 - Fuel Pressure System Malfunction
    (52) - Present
    After that I checked the Fuel Pressure feedback. With warm engine was between 700kPa and 5000kPa without doing anything . With a cold engine the fuel pressure was almost stable.
    So....how can I find out if it is the pump..the sensor...or the regulator.
    Thank you very much!!
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Jun 2012
    Edinburgh
    I've read the thread. So after you changed only the regulator and the sensor the car was ok for about 8-9 months? Because I would go for the cheaper option to change only regulator and sensor.
    I've read somewhere else that the HP oumo is damaged if the pressure is under 600kPa wich is not my case.
    Engine : 2.2 Direct
    Yes thats correct.
    Jun 2012
    Edinburgh
    Thank you kenp!
    I will search for fuel sensor and regulator. Do I need to change them both? Any recommendations?
    Engine : 2.2 Direct
    Dont know that you need to change them both.. i did, as i wasnt sure witch one was faulty...
    Jun 2012
    Edinburgh
    any recommendation for buying the regulator? because I read on the forum that there are some problems with certain ones...
    Engine : 2.2 Direct
    i would go for the dealer one on that.. as there was introduced a new and revised one.
    Jun 2012
    Edinburgh
    thanks! i'll do that!
    Jan 2012
    Silverstone village
    Have you tried replacing the fuel filter ?
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  3. H.p fuel pump pressure regulator problem 2.2 direct
    By Dobs in forum Engine & Drivetrain
    Last Post: 3rd August 2009, 18:06
  4. Replies: 4
    Last Post: 22nd June 2009, 13:56
  5. 2.2i direct fuel pump / regulator problems
    By alanatrr in forum Engine & Drivetrain
    Last Post: 19th January 2009, 21:37
p1191-52
