Thread: Cutting an Exhaust Pipe...?
    South east
    Default Cutting an Exhaust Pipe...?
    Has anyone tried cutting a 2.25" exhaust pipe while it's still on the car, using a 4.5" angle grinder, where you have to cut it all the way through from the bottom of the pipe rather than being able to cut it from all sides? Can it be done or is the disk just too small? Thanks.
    Vectra-C Extreme Poster Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    Too small i would have said mate grinder body will get in way might be better with 5 inch grinder
    Jun 2011
    wolverhampton
    Cheap exhaust cutter of the chain type
    Feb 2011
    Selby
    An angle grinder can only cut as deep as the centre clamp, which is about 40mm in diameter. So a 115mm disc (4.5") can only cut an absolute maximum (115-40)/2 = 37.5mm. Or in ancient units, 1.5". Ok, so you can get at a bit more by going in from the sides, you're not going to get to the bit of pipe nearest the floorpan.
    Chain type pipe cutter is the correct tool to use - it cuts all the way round at the same time, and only needs 10mm or so clearance. Also leaves a much neater cut and doesn't heat things up so much.
    South east
    You're right about using a chain type cutter, but they're pretty expensive for something I'll use only once . I've decided to get a garage to do the job (cutting out the flexi section of the exhaust and fitting in a new stainless steel one I've bought from MIJ), as there's another issue - having to remove three quarters of the exhaust in order for the new part to go in, as there's obviously an overlap of the pipes from new to old. Doesn't seem feasible to do all that while lying under the car with the exhaust 3" from my nose.
    Jun 2011
    wolverhampton
    Just get mij to do it for ya
    Regular Member Adam8220's Avatar
    Apr 2011
    Ripley, Derbyshire
    Quote Originally Posted by sriandy View Post
    just get mij to do it for ya
    how good are mij, i'm thinking of having them do my dual exit conversion..
    Regular Member montyfert's Avatar
    Jan 2012
    wales
    am sure a hacksaw would do the job.
    Feb 2011
    Selby
    Quote Originally Posted by montyfert View Post
    Eventually, yes it would. But it'd take quite some time, and underneath a car on axle stands there's not a lot of room to move your arms.
    South east
    I paid £21.50 for the stainless steel flexi section from MIJ (the whole section including innards and end caps plus clamps, not just the gauze). It'd cost me twice that in petrol to get to MIJ and back, plus the payment for their labour...lol
    A hacksaw wouldn't work - at the front end of the flexi the transmission tunnel is so small there just isn't enough room to get a proper size hacksaw against the exhaust pipe; even a junior hacksaw would be a tight fit but it'd be useless at cutting.
  1. Flexi Exhaust Pipe
    By SarahP in forum Troubleshooting
    Last Post: 1st January 2012, 20:14
  2. cutting through an exhaust pipe - what tool?
    By Caveman_nige in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2010, 00:56
  3. Exhaust pipe?
    By mishima in forum Styling
    Last Post: 30th August 2010, 21:56
  4. Replies: 36
    Last Post: 3rd August 2009, 23:39
  5. Exhaust pipe sizes
    By carl bear in forum Engine & Drivetrain
    Last Post: 21st April 2009, 13:51
