Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Thread: traction control switch problem please help
    redcar
    Default traction control switch problem please help
    I've just bought a traction control switch for my Vectra. Took the blank switch off and put the traction control switch in and nothing seems to happen. It's all inserted correctly and when I press the button I'm getting no response
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    They only work out of the box on about 50% of early pre-facelift models. Facelifts have no chance without extra work/wiring.
    On some models it's possible to get it working by adding a couple of extra wires, one from the ABS ECU to the X1 plug in the passenger foot well and one from the X1 to earth. I've done this on mine and mine now works, however this only seems to work on petrol models.
    Regular Member John Bishop's Avatar
    Oct 2010
    Is the blue connector located behind the blank, it may need wiring in. Also do you have tc fitted?
    redcar
    Quote Originally Posted by John Bishop View Post
    Yeah it's got the blue adapter. I've fitted to that and no response and yeah the car has traction control. Quite annoying really and don't fancy doing any additional wiring as I'm not very good at electricals
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Its more for looks... has it worked for anyone who's fitted it?
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Quote Originally Posted by Chunklamb View Post
    Didn't read my post then
    As said in a lot of cases (about half ish) with early pre-faces, you fit the switch and it just works (and yes there's been a lot of cases of that). In a lot of others you can add the additional wiring and it will work (as I have with mine). However as yet, to my knowledge, no-ones got it working on a Diesel.
    Oct 2010
    Mine is the same jonny. Bought the switch as it has ESP and is crap in the slightest of snow but it did'nt work
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    my face-lift is all wired up front switch to abs module. it maybe because i have cd70?
    Oct 2010
    I have the cd70 dan. All it does is light up when you open the drivers door pmsl
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    andy.l checked my wiring because am going to try and retro fit tc by upgrading the abs module which i have already got deans going to try and enable it.
  1. Traction control switch
    By larrysSRI in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2010, 02:06
  2. traction control switch
    By Beavis in forum Parts for sale
    Last Post: 13th April 2008, 08:15
vectra esp module
vectra traction switch short pin 11
