Thread: Air Con Pulley
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    confused Air Con Pulley
    I have been wondering for a couple of weeks now if my air con worked or not and i have come to the conclusion it doesnt, i was under the bonnet today and noticed the air con pulley or what ever it is isnt turning when the car is running i would say this is not normal and surely cant be doing the belt any good anyone any ideas tried to turn by hand and the middle bit spind freely but the actual pulley wont budge
    any help appreciated
    Dec 2011
    Seaham
    I beleive the compressors have a clutch on them, so they only engage when the air con is switched on.
    Dec 2011
    liverpool
    6 Post(s)
    but surely the pulley should be spinning when the engine is running then the clutch engages an starts the compressor up i tried switching it on and of but never budged at all just doesnt move as i say even when the engine is running
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    It should still be spinning as you say. Sounds like its fubar
    Dec 2011
    liverpool
    6 Post(s)
    ye had the same thought how easy or not are these to remove ?
    Jun 2009
    South Coast
    Easy, removed aux belt, disconnect the wiring and unbolt the compressor.
    Jun 2009
    South Coast
    ignore that removal advise, that refers to mine where i have already disconnected the aircon system. You will need to go to an aircon place with your new compressor and have them swap it for you as they need to dispose of the chemicals/gases properly and then refill it afterwards.
    Dec 2011
    liverpool
    6 Post(s)
    so i cant just undo the air con pipes let the gases escape and take it of i would have to get an aircon place to get them to remove the gases or have i read that wrong
    Barrow In Furness, Cumbria
    I think its illegal to vent the gas to the atmosphere.
    Engine : 1.9 CDTi
    Quote Originally Posted by Chris SRi View Post
    Highly and fine'able:
  1. Y22DTR pulley
    By Allan-DTI in forum Engine & Drivetrain
    Last Post: 2nd February 2013, 20:20
  2. Bottom Pulley???
    By LeylandRick in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2012, 23:00
  3. Broken pulley !?!?!?
    By VecPower in forum Engine & Drivetrain
    Last Post: 3rd August 2010, 09:11
  4. Crankshaft Pulley again!
    By ANDY H137 in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2009, 14:34
  5. Bottom Pulley
    By kinger in forum Engine & Drivetrain
    Last Post: 8th August 2006, 09:05
vectra aircin pulley
