Thread: Vectra 1.9CDTI 150 only boosts after 3500rpm
    Regular Member fred_7's Avatar
    Jul 2009
    Lisbon
    Default Vectra 1.9CDTI 150 only boosts after 3500rpm
    Hi
    I'm not new at the forum but it is the first time I post.
    I have a Vectra 1.9 CDTI 150bhp that now is giving me a headache.
    When I bought it 37000km as a service vehicle from a dealer I found an annoying huge juddering at around 1750rpm. I only felt it up hill on higher gears when revs took a little while to move. If it passed fast through those rpm I didn't felt it.
    The dealer said they replaced the air conditioning unit by saying it was not moving freely. I do think the car was only there sitting for a week and they did nothing.
    I ignored that issue and learn to live with it.
    Now I'm having an issue that is really bothering me. I read many post through the forum but I don't see anything similar.
    The car is used mainly from my wife and she complained the car had a loss of power. I was testing it and felt no power until 3500rpm where the turbo kicked with power.
    I went to see a friend that connected the computer to ECU and he tested all components, like EGR solenoid, swirl bar, MAF, etc. No issues found. He advised me to do a long trip because it could be the turbo flaps full of carb.
    I went on vacations and did around 400km(~250miles) on a trip to south of Portugal. Now it is better and not doing so bad below 3500rpm but it is still noticeable the boost before and after 3500rpm.
    It is like this:
    On cold start the 2nd it does great and pulls like a train!
    After that 1st time the 2nd gear at 2000rpm has the same boost as 3rd and it starts to show 2 flat spots. One at 1800 and other at 2200rpm. Very strange...
    These flat spots are felt good in 1st and 2nd and diminishes while moving on with the gears. I don't feel so much the loss of power on 3rd and so on as on 1st and 2nd.
    Next week I will be cleaning boost control solenoid, boost sensor and EGR.
    Do you have any idea what maybe happening? Can this be a carbed turbo?
    thanks in advance for your comments.
    Your are all welcome to discuss.
    Regards
    Jul 2009
    Lisbon
    I forgot to say mine is a facelift model from february 2006 with 92.000KM (57.000miles).
    Jul 2009
    Lisbon
    Hi
    I have to make a correction. In the title I say "only boosts after 3500rpm" but it is wrong. It boosts well after 3000rpm.
    Can anyone help me?
    Anyone had this issue and guide me?
    Regular Member amand's Avatar
    Feb 2011
    west London
    vaccum hose split, intercooler pipe split.
    Jul 2009
    Lisbon
    Hi amand.
    I just saw your answer now and while you were writing it I was checking the engine.
    You couldn't be more sure!! The vacuum hose has a split!
    I will post some pictures soon.
    Is this a common issue? I read that thread about the vacuum hose but I didn't have any lights, limp mode after 3000rpm and I had 2 flat spots.
    Thank you!!
    Feb 2011
    west London
    You're welcome fred_7 I assume it is a wear and tear issue over a long period. Its best to replace with silicone hose/tubes.
    Jul 2009
    Lisbon
    The car is from 2006. Maybe some more issues in the future...
    I was searching on the internet for silicon tubes. Where can I order this kind of tubes? Do you know any online store?
    Feb 2011
    west London
    ebay look for a 4mm silicone tubes
    Jul 2009
    Lisbon
    Hi,
    Thanks you!
    I will order now.
  1. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  2. 2.2 direct struggling over 3500rpm
    By ScottyV6 in forum Vectra C / Signum Troubleshooting
    Last Post: 29th June 2011, 19:47
  3. Very high idle speed (3500rpm)
    By CodeV in forum Engine & Drivetrain
    Last Post: 19th February 2010, 01:08
  4. 1.9cdti 150, engine light/no power @3500rpm
    By DVectra55 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd September 2008, 22:54
  5. 1.8vvt design, noisy @ 3500rpm 70-90mph
    By jordy32 in forum Engine & Drivetrain
    Last Post: 21st March 2007, 22:11
