Results 1 to 10 of 15
Thread: More AC Woes...
    Regular Member Munkey's Avatar
    Jun 2012
    United Kingdom
    Default More AC Woes...
    To add to the list of people with AC issues recently.
    After driving for 6 hours without any problem I switched the AC off as was loosing the feeling in my feet. When I switched back on... warm air
    Cannot see any holes in the condenser although its not getting hot, all seems to kick in when pressing the button (noise, revs go up etc).
    A little peeved, as on the M25 in 30 degrees with no air con was slightly uncomfortable.
    Thankfully car is under warranty as only had for about 4 weeks now...
    I have the little button with the snowflake, is this the only control for the AC or is there a software controller for it?
    Oh, fuses seem fine.
    Regular Member MattVecVXR's Avatar
    Mar 2012
    Torpoint, Cornwall
    Trim : VXR
    Engine : 2.8 V6 Turbo (280)
    Mileage : 82000
    You'll have a leak somewhere then, me too. I've not had time to investigate it but if it's not run often enough, the seals can dry and leak. I'll be getting mine to the refigeration workshop at work when I can. They can vac it down and charge with nitrogen to carry out a leak check, then if it's tight, recharge. Otherwise it's fix the leak, and retest it before charging.
    Good job yours is under warranty!!
    Jun 2012
    United Kingdom
    Quote Originally Posted by CDTiMatt
    Am hoping there will be no problems getting sorted with the warranty as have a long drive on 4th August
    Jun 2012
    United Kingdom
    Just had the system pressure tested - all fine, looks like the compressor is duff
    Go to go through the warranty provider - not really something I can complain about the garage I bought from as was working fine when I got it.
    Does anyone know potential "silly" problems that can cause it not to work? Would prefer to have a play tomorrow and just have her fixed.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    U do have the knob turned down to cold when you switch the AC on?
    Jun 2012
    United Kingdom
    Yarp, just got her back from a re-gas. They let me know the compressor isn't engaging so wanted to know if there is a relay prone to failure or similar. It's the 2.0T and am trying to find the relay / fuse map for it...
    Jun 2012
    United Kingdom
    Took her into an AC specialist. Going to be a new compressor and clutch. They are also going to try to get the pipework replaced as there are several dry joints...
    Hopefully will be covered by the warranty...
    Sep 2010
    Had my other SRI in at the dealers on Friday (6th visit!!)... another dye test, found a small leak on the condenser (previously advised as fine)... run a sealant through the system,.. system drained by Sunday morning!!... car will be scrap before they sort this!!!! (2008 car!).
    am hoping VX will allow me to take it to an AC specialist
    Regular Member gaz1965's Avatar
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    I was under the impression that ac was not covered on the warranty. When I tried to get mine done I was told that it wasn't covered.
    Sep 2010
    Quote Originally Posted by gaz1965 View Post
    It depends what the fault is and it should under the manufacturer's warranty as it it 'mechanical' and not 'trim'
    also,.. my Warranty Direct covers the AC system.
  1. new car woes
    By dunkf in forum Engine & Drivetrain
    Last Post: 11th July 2011, 11:55
  2. New car woes
    By hack in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 19:58
  3. Mot woes!!
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2010, 10:14
  4. air con woes
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2008, 19:23
  5. More Woes
    By VauxVeteran in forum General Chat
    Last Post: 15th April 2008, 23:52
