Results 1 to 3 of 3
Thread: Power steering problem? Help appreciated.
    New Member silver griffin's Avatar
    Apr 2008
    Liverpool
    Default Power steering problem? Help appreciated.
    Hi guys.
    I have a Fairly quiet sort of whining / droning noise coming from my Vectra SRi.
    This is mostly heard when I am stationary (say at traffic lights).
    The noise stops when I turn the wheel (even slightly)... But then returns.
    I wonder if it is just needing power steering fluid? I have found the reservoir but not sure what the correct level should be, I would say mine is about half full. Should it be to the line on the dipstick??
    Also not sure what fluid to use to top up..
    Vectra SRi 2008(08) 1.9 CDTi.
    Thanks.
    If it is the reservoir under the headlamp, there are two marks on the side and the level must be between these two marks
    These Power Steering units are dreadfully noisey
    Apr 2008
    Liverpool
    Mine is at the back of the engine bay below the oil filter.. Cannot see any markings on the reservoir itself nor the dipstick.. However there is a change in the thickness of the dipstick itself so I'm assuming this may be the 'level mark '?
  1. power steering problem
    By Mikewigan in forum Troubleshooting
    Last Post: 1st May 2012, 07:28
  2. power steering problem
    By mr.d in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2011, 22:33
  3. power steering problem...!!!!
    By rioni in forum Suspension, Wheels & Brakes
    Last Post: 11th May 2011, 18:36
  4. power steering - problem?
    By wardy in forum Suspension, Wheels & Brakes
    Last Post: 31st August 2008, 17:55
  5. Power Steering Problem
    By llaregub in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2008, 11:35
