Thread: cdr 2005?
    Regular Member Legion84's Avatar
    Jan 2012
    Stockton On Tees
    Default cdr 2005?
    Hello guys, yesterday I pulled the unit out usedd a coat hanger to pop the pins to pull it out was tricky no doubt lol... I picked up a nice little sub off the car boot sale for 5 quid,
    once I got it out I hooked the sub up by putting it negative and positive on the back rear speaker on the right side, the head unit powered It but got kinda warm ill probably need an amp, so disconnected it from the head unit.. but if I was to leave it on do you think it would damage or burn the cdr out... what upgrade could be used, a nice one to keep steering controls working? Cheers
    Feb 2011
    Selby
    Yes, the extra load would eventually cause damage to the output transistors in the amplifier in the head unit. You need an additional amplifier to drive the subwoofer. There are plenty on the market that will take speaker level inputs directly from your rear speakers without loading the head unit.
    Jan 2012
    Stockton On Tees
    thanks rich, do you know where the best place to wire it up would be, i'm thinking of just maybe soldering it on to a rear speaker once i get an amp, as the cdr2005 cables into it are all on a plastic connector and save me the trouble of trying to get it out again.. any suggestions thanks
    Jan 2012
    Stockton On Tees
    upon further research it looks like i will need to lose the rear speakers, and add a line driver linked below pc1 601 from halfords, to convert speaker wire to low amp rca connectors to wire it to an amp? can the wires be pulled out the iso block/loom or do i need to cut them
    Feb 2011
    Selby
    No. There are plenty of amplifiers that you can quite happily wire in parallel with the rear speakers to derive a subwoofer output, without affecting your rear speakers. You do not need to convert to line level or lose your rear speakers.
    Might be better to speak to a car audio shop that wants to help you rather than sell you things you don't need.
    Jan 2012
    Stockton On Tees
    Thanks rich that's good to know, your right I should call in to a store and see what can be sorted, I could but don't want to change head unit with it having the controls on the steering wheel would be nice to get a deep bass without damaging the hu, cheers
  1. CDR 2005 Aux mod
    By Domchapp in forum Styling
    Last Post: 20th February 2015, 14:19
  2. 2005 2.2 radiator to fit a 2005 1.9 cdti 120bhp
    By IRvectra786 in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2012, 08:59
  3. Cdr 2005
    By Das in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2010, 01:44
  4. Cdr 2005
    By penfold2000 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2008, 21:33
