Thread: Rear Brake pads
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Default Rear Brake pads
    Any body had problems fitting pads.
    Had a set from Euro Car Parts-Pagid pads and found the lugs on the pad that locates into the piston would not fit. The lugs were about 3-4mm out. So bought another set from Allparts-Delphi and found these were the same.
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    I've not the had the rear pads out on my vec but if they are anything like other vaux's you need almost squeeze the clip into place, sometimes they are tight but nothing a pair of pliers can't solve, or am I understanding your problem incorrectly?
    Regular Member MattVecVXR's Avatar
    Mar 2012
    Torpoint, Cornwall
    Trim : VXR
    Engine : 2.8 V6 Turbo (280)
    Mileage : 82000
    Swap them around, the pad with the clip should be next to the piston.. the lugs should be a different distance on the inside and outside pad.
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    11 Post(s)
    If the lugs fitted into the piston, the piston wouldn't be able to rotate, thus stopping the footbrake and handbrake from working. Also it would knacker up the caliper and piston as well.
  1. rear brake pads
    By waynevvti in forum Suspension, Wheels & Brakes
    Last Post: 9th April 2012, 16:17
  2. Rear Brake Pads
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2011, 18:25
  3. Rear Brake Pads
    By IWC in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2010, 11:55
  4. Rear Brake Pads
    By CHRISSMART41 in forum Suspension, Wheels & Brakes
    Last Post: 16th October 2007, 18:22
