Thread: 1.9 cdti 120 - locking tool for timing belt renewal
    Jul 2012
    Ireland
    Default 1.9 cdti 120 - locking tool for timing belt renewal
    Hi All,
    I'm new to the forum and I'm thinking of doing a DIY change of my timing belt.
    I need to set the crankshaft at No. 1 TDC but i can only accurately do so with the locking tool (as advised by haynes).
    I saw some previous comments on just marking it but i'm a bit cautious as i've no previous experience in a DIY timing belt change without the locking tool (plus that was on a "spacious" 1.9tdi!!)
    Any thoughts?
    Full Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    9 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    dont risk it, get the timing set otherwise youll regret it if you do it wrong!
    Jul 2012
    Ireland
    Does anyone have this tool for borrowing? It'd seem a waste to buy it and just use it once. Just my opinion.
    South east
    You could buy it and sell it on ebay.
    Jul 2012
    Ireland
    Yeah, easiest option i suppose. I called a local autofactors and they quoted €150!!! They are cheaper on the web though.
    Thanks.
    May 2012
    9 Post(s)
    Trim : Exclusiv
    http://toolstoday.co.uk/shop.php?sec...t+Drive+Diesel
    this is the one i got, im just gonna let it gather dust till i need to do another timing belt/water pump change! its alot cheaper than repairing a mistimed engine!
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by sog View Post
    Hi All,
    Any thoughts?
    You need to set the tension on the timing belt correctly, as you have no previous experience I would suggest taking it into a competent garage.
    May 2012
    9 Post(s)
    Trim : Exclusiv
    Quote Originally Posted by C-Owner View Post
    just put a bolt in the lower timing case hole and lever with a screwdriver till the arrow lines up with the tension mark!
    Regular Member srijas's Avatar
    tiverton,devon
    dont know if its to late but you can get a universal locking tool for £20 on ebay and theres a complete video on youtube although thats for the 150 model
    Jul 2011
    Norway
    Timing on cdti is easy. Just make your own mark for the cam and use the stock on the crank. No tools needed.
    Ive done a couple of these the last months. Just make sure you also change the waterpump.
  1. timing belt tool.
    By BigWilko in forum Y & Z30DT Specific
    Last Post: 22nd January 2013, 15:15
  2. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  3. PLEASE HELP!!! Timing belt renewal issue
    By 123rado in forum Engine & Drivetrain
    Last Post: 11th November 2012, 16:24
vectra 1.9 120 rear shouker
1.9 cdti locking tool
