Results 1 to 10 of 11
Thread: AC condenser
    Nov 2010
    Maidstone
    Default AC condenser
    Had the car 2 years now and air conditioning has never worked, got it checked by a mate and was a hole in the condenser, bearing in mind the ac hasnt been used for a while how do i know if the compressor still works, as i can probably run to a new condensor but if the pumps gone its not worth starting with? Any help appreciated
    Regular Member CK1's Avatar
    Oct 2011
    Dublin
    How much does a new condenser cost btw?
    Regular Member yessof's Avatar
    Jan 2008
    west yorkshire
    Took mine to an aircon specialist. They filled the system with some type of gas, not refridgerent and dye. Then switched the aircon on, checked the compressor pump etc and found the condensor was holded. Removed the gas from the system and charged me £10. If your going to change the condensor be warned you will need at least 2 new seals, I fitted a new dryer as well as a condensor,so I needed 3. They cost me £31 from the stealers!!!
    Regular Member John Bishop's Avatar
    Oct 2010
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Quote Originally Posted by John Bishop View Post
    Thats a cheap site for condensers my local factors wants £113+vat for a new condenser for my 2.2 direct
    Jan 2008
    west yorkshire
    Have a look at Advanced Radiators. Think its www.adrad.co.uk. Thats where mine came from.
    Regular Member marky2027's Avatar
    Northumberland
    Quote Originally Posted by CK1 View Post
    I have just done mine. £67 including delivery on fleabay
    Barrow In Furness, Cumbria
    If the compressor doesn't work then expect to pay around £700 for a new one fitted. I got mine done under warranty. Best to speak to an aircon specialist to see if they can tell before you start replacing bits.
    Aug 2010
    Leeds
    This hole you have can you not get it repaired? Try a radiator specialist.
    £20.00 fix.
    Nov 2010
    Maidstone
    i didnt think you could repair ac condensers?
  1. Condenser question
    By bbdp in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2012, 17:19
  2. A/C condenser
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 22nd August 2011, 19:59
  3. Air Con condenser broke
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2011, 20:17
  4. A/C condenser
    By xaviroller in forum Bodywork & Interior
    Last Post: 8th July 2009, 11:56
