Thread: hello to all, just bought my first vectra c 2.0tdi.
    Jul 2012
    cheshire
    Default hello to all, just bought my first vectra c 2.0tdi.
    can anyone please offer advise on the following problem, glow plugs dont stay on long enough, get short period of grey smoke (big cloud) on start up. i have changed glow plug relay, had glow plugs checked and had egr valve removed and cleaned, none of the above work has resolved my problem regarding cloud of smoke on start up. HELP
    Regular Member richy1974's Avatar
    Jun 2012
    leek
    I think vauxhall do a ecu up date but its a bout £100 quid
    Regular Member Legion84's Avatar
    Jan 2012
    Stockton On Tees
    Welcome peter, hope you get it sorted
    Jul 2012
    cheshire
    thanks mate but would like to try cheap options first..cheers
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Its a DTi they all smoke to a varieing degree , mine is exactly the same , things to try .
    1 clean boost sensor
    2 clean upper inlet manifold
    3 put about half a bottle of stp diesel injector cleaner in with your next fill up
    and still loving it
    Jan 2012
    Stockton On Tees
    Yeah you could try what bob has suggested, my old vectra didn't smoke but it had twice as less miles on clock, this one smokes on start up when it first fires up get a white puff of smoke and then clears straight after, still a little bit of black smoke on heavy acceleration but up to now not using oil and runs fine, I couldn't get the manifold spotless but opened the airways on it and cleaned swirl bars best I could took about 5 hours 90mins of cleaning included, if you do decide while your going to get air into the fuel system might be an idea to change fuel filter, and to bleed use the method of loosening nuts on the injector pipes into the engine worked a treat gettin air out of it, I tried everything else... lol
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by bobssignum View Post
    all diesels will give a puff of smoke when they start.
    Is the car taking a while to fire though? If so it may be worth checking the leak off pipes as they can perish (and the t-pieces can crack) which allows diesel to drain back into the fuel tank.
    As the DTi does not have a lift pump in the tank it has to use the engine fuel pump to pump diesel from the tank every time before firing
    Jul 2012
    cheshire
    Thanks to all for response`s, there hasn`t been any issues starting the car (yet), just the large cloud on start up, recently stayed at a b&b in York, couple of guests outside having a cig had to go back in because i started my car. (embarrasing to say the least). Not sure of location of boost sensor on 2.0tdi. Do i need to purchase any gaskets to do upper inlet manifold?.
    Engine : 2.0DTi
    Mileage : 73350
    DTI engine layout 2.jpgpic 1.jpgThe upper inlet manifold has just a metal gasket under the 4fixing bolts , usually just a clean and replace will suffice.
    Pic enclosed is off a 2.0 DTi but it shows you where the boost sensor is and other bits, some you will have and some you wont
    The second pic shows you the vacuum hose connectors its worth checking these as they are a regular source of problems with the DTi s mainly due to perishing /cracking .
    Follow these hoses around the engine checking each one for cracks .
    what is usually done on here is we buy 3 meters of 3mm silicione tubing off e- bay and then cut to size the replacement pipe
    cost,s about £7 or £8 on e bay. as opposd to £30 for the rubber connectors from a stealer
    and still loving it
    Jul 2012
    cheshire
    thanks very much for the in depth info, i will check all as you described, cheers mate.
  1. thoughts on Audi A6 2.0TDI S-Line
    By chewy71 in forum General Motoring Chat
    Last Post: 13th August 2012, 09:27
  2. vectra c 2.0tdi on 52 plate
    By hgvdriverpeter in forum Engine & Drivetrain
    Last Post: 23rd July 2012, 21:58
  3. Does anybody know if this will fit a 2.0TDI
    By danny1992 in forum Diesel Engine related
    Last Post: 9th November 2010, 17:05
  4. 2.0TDi Queries
    By moonym20 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2009, 14:43
  5. vectra 2.0tdi
    By ovalfan in forum Engine & Drivetrain
    Last Post: 5th February 2009, 00:14
vectra c 2.0 tdi
