Results 1 to 10 of 13
Thread: What tyres should I get… Advice needed for a clear answer!
    Regular Member coldo's Avatar
    Scotland
    Default What tyres should I get… Advice needed for a clear answer!
    I am getting a bit fed up with the droning and lack of grip I am getting off the tyres which are fitted to my Vectra at present. So I was going to change them for some midrange tyres.
    Problem is I can’t work out which size I should fit.
    I have fitted Astra XP Penta’s to the car which are 18” alloys and presently have 225/40/R18’s fitted.
    I searched the site and found some people have fitted this size of tread, some fit 235/45/R18, some go for 225/45/R18, some go for 235/40/R18, etc…
    So I guess my question is which tyre size is the correct fitment for
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    I have 235/40/18 its one of the factory sizes. Tyres wise on the back I am trying the nt8000 from Neuton. Good price and no complaints so far.
    Regular Member Paulwr's Avatar
    Mar 2012
    Ormskirk, Lancs
    Vehicle : Astra H 1.8 VVT
    Trim : SRi XP 3dr
    Engine : Z18XER
    Mileage : 12k
    I run 18" multispokes with 225/45/18 Avon ZZ3 tyres. Quiet, grippy, feels really stuck to the ground.
    Regular Member stephen_brady's Avatar
    Jan 2012
    N.Ireland
    Ithink the 'factory fit for this rim size is 225/45/18. This is the closest reflection of 22/50/17 as far as I know to keep the MPG etc in track, other wise you should really be getting your car tech2'd to have the MPG and mileage calbrated.
    Regular Member 4ndy's Avatar
    Oct 2010
    Glasgow
    It depends on the rim width aswell. My original elite wheels were 7.5" wide and had 215/50/17 fitted. My new wheels are 8" wide and have 225/40/18 fitted. The tyres look a little stretched and are running slightly slower so as soon as they're done I'm going for 235/40/18 which is the closest possible match to the originals.
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    12 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    I agree.
    8" rims are made for 235 or 245 mm wide tyres. I'm even thinking seriously about fitting 245/35/19 to raise the car a bit and filling in the wheels wells better... Provided this size exists and can be found. Its radius is only 3.65 mm more than the original 215/50/17 factory mount (I'm still in group 2 with the 235/35/19) and still inside the tolerance range.
    Your idea of 235/40/18 is the best possible choice for 18" IMHO. The vectra behaves very well on 235 mm wide tyres (I would never put narrower ones : the car is heavy and prone to slip from the ass, though 225 mm are still acceptable).
    Now 18" rims are generally often just 7"1/2 wide, so 225/40/18 is most commonly fitted (OEM approved), but it puts you into group 1 and needs a Tech2 reprog. So, Coldo, if your rims are wide enough, try to fit 235/40/18 instead. If the tyres flanks don't protrude too much from the rims, you won't regret it (plus you won't have to reprog the car).
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    I have Falken Ziez Ze912's in 225/40/18's on 8 inch rims, purely because they were cheaper than the 235/40's
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i ran 235/40/18 on my sportstars for a bit extra rim protection, the neutons are good by all account's, my dad and bro have them fited to there car's (but not in those sizes)
    iirc Nick 2.2 has 235/40/18 neutons on his sportstars now
    HTH
    emec#1
    Regular Member unikarl's Avatar
    Nov 2011
    Grimsby
    I have 235/40's on my 18" xp2's which will more than likely be the same width as your pentas. I opted for neuton nt5000's as the reviews were good and so was the price. They are quiet and grippy. I'd recommend them to anyone.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    im running 245/35/19 Neuton 5000. brilliant tyres, cant fault them. im going faster and faster round corners and it never fails. im trying to find the tyres limits! good price, good grip and low noise compared to my ****ty FULLRUNS. would take it a bit easy in the wet though still.
  1. hi im new, advice needed (tyres)
    By waynehiscock in forum Vectra C / Signum Troubleshooting
    Last Post: 27th February 2012, 08:30
  2. caliper carrier bolts quick answer needed
    By james walker in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2011, 17:23
  3. answer needed please
    By vectragsi3.2 in forum Suspension, Wheels & Brakes
    Last Post: 16th June 2010, 19:31
  4. Advice needed on Tyres
    By bushygrunt in forum General Chat
    Last Post: 21st April 2009, 12:23
  5. 215/50 17 Tyres Urgent Advice Needed
    By aaruck in forum Handling & Braking
    Last Post: 12th November 2008, 23:44
