Thread: Drain Fuel Filter 1.9 Cdti 120 2006
    Reading
    Default Drain Fuel Filter 1.9 Cdti 120 2006
    Had a cold starting problem for a while and tried to do this operation. (Z19DT engine).
    Couldn't see how to release filter from it's cage, but anyway undid the drain valve a turn or so. At first the system was not pressurised (i.e. car stood for a day or three) no water coming out, but a hissing as if air is going in, but worried about having to re-prime, so didn't let it hiss for too long. Afterwards it seemed to start a bit better. I then did the same, but with system pressurised (i.e. after running and then stopping the engine) nothing comes out when the drain is opened.
    Now it is warm weather I don't think I can blame the glow plugs. Starting problems always occur if car standing for a while, even if I let the pump fully pressurize first. Always OK once it has been run for a bit.
    Any ideas or explanations gratefully received?
    Nov 2010
    East Midlands
    Trim : design
    Welcome to the club -What mileage have you done - could be the starter motor starting to wear as they get older they start to turn the engine over at a slower speed insufficient to start the engine as it should do - there are loads of posts on this if you do a search
    Reading
    Quote Originally Posted by alcutler View Post
    Thanks for the suggestion. Car has only done 50K, and I tend to do mostly long journeys, will follow that one up anyway when I am sure it's not some sort of starvation problem. It seems to crank OK, catch and then falter several times.
    Jan 2012
    Gloucestershire
    Just for info, priming the fuel system on the 1.9 is not a problem. Even with a filter replacement, you need only turn the ignition a couple of steps to get the fuel pump on (you'll hear gurgling and whining a bit), then back off, repeat until no gurgling and you're ok to start.
    Still, this doesn't help you with the problem - follow alcutler for that!
    Reading
    rolleyes
    Quote Originally Posted by DieselWig View Post
    Thanks, that takes a bit of pressure off! I suppose I could let it bleed air until it stops and see what happens. I am not absolutely sure it's taking air in, might be letting it out!
  1. How to drain fuel filter housing?
    By NoFinPhish in forum Y & Z30DT Specific
    Last Post: 29th November 2012, 20:31
  2. cdti Fuel filter drain
    By Derek Mc in forum Diesel Engine related
    Last Post: 2nd October 2010, 16:05
  3. cdti 150 diesel oil filter drain stub
    By veralum in forum Engine & Drivetrain
    Last Post: 12th April 2010, 16:38
  4. CDTI Fuel filter
    By crgv6 in forum Engine & Drivetrain
    Last Post: 26th November 2009, 21:27
  5. How do you drain the diesel fuel filter of water
    By chrisvectra in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 11:04
vectra c fuel filter housing drain
vectra 1.9 cdti fuel filter plug
vauxhall vectra diesel drain fuel filter
diesel fuel filter drain vauxhall vectra 120
vauxhall vectra 1.9 cdti how to drain water out of diesel filter
how to drain fuel filter vectra c
how to drain vectra diesel fuel filter
