Thread: DIY rust repair around filler cap
    Leeds
    Default DIY rust repair around filler cap
    Hi - wonder if anyone would be able to share their knowledge on this, wife has a Ford KA with a very common problem of rusting around the filler cap.
    As soon as I got the car a couple of years ago I cleaned all the crud out from under the wheel arch and around the filler cap / neck on the inside and painted with Hammerite - I'm pretty sure this has slowed things down a bit. But now it come through and I need to sort this, I've had a few quotes from garages to get the section cut out and resprayed and I can't really justify spending a small fortune on this bearing in mind how much the car is worth.
    So I want to attempt a DIY fix and would like to hear from anyone that has actually done this - I know I'm never going to get a perfect finish or solution but if someone could point out the steps, tools and bit's n pieces I need it would be greatly appreciated.
    Below are some pictures of the affected area:
    Thanks - J.
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Tbh you could stick as much filler in there as you want but it'll just come back within 6 months or so. How much were you quoted to get a panel welded in?
    Leeds
    £750 from a garage local to me and £1100(!) from a Ford bodyshop, tbh the Ford bodyshop said these were a real pain and take a lot of time to get right. Problem is at that price on a car that's probably worth £1000-£1500 it's hard to justify spending it. If I get time to take it somewhere else to get a quote I will.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Lots of this on the ka owners forum. Im just about to sort it on my sisters.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Ouch! I can see why you'd want to fill it now lol
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Im considering seeing how much a new panel is given she has also dented it.
    Or theres these http://www.ebay.co.uk/sch/sis.html?_...d=130533868784
    Leeds
    Yeh posted on the KA forum as well, but not as many people on there! The replacement panels are the common way to fix this ... I can only assume that Ford started to do these as so many KA's are like mine. Obviously trying to do the replacement panel is not going to be possible for a DIY'er unless you happen to have a garage full of tools to do it properly. It has been mentioned to cut out the affected small areas of rust and use a rush inhibitor and fibreglass / filler to patch up - appreciate this is not going to be a long term solution. Basically not sure what to do with it now ...
    Sep 2010
    I was going to suggest similar to Ziggy,.. fit an aero type filler cap to hide the rust then part ex or trade or sell
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    any repair in this area needs to be welded as it is within 30cm of seatbelt mounting .
    Leeds
    Quote Originally Posted by DTi Elite View Post
    oh, it just gets better this!
  1. Rust on roof (repair)
    By shiver2k11 in forum Bodywork & Interior
    Last Post: 25th February 2012, 00:35
  2. Rust?
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2011, 21:38
  3. Need some help with rust.
    By Vaux-Man-G in forum Bodywork & Interior
    Last Post: 17th March 2011, 14:40
  4. Rust!
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2007, 14:30
ford ka fibreglass filler cap repair
rudt by filler cap on corsa repair
rust on filler cap
