Results 1 to 10 of 15
Thread: No aircon!
    Sep 2010
    northamtponshire
    Default No aircon!
    Hi guys
    When I switch fans on I only get warm air or air that's the same temp as outside. I rang an aircon company local to me who offer a full service and recharge for £59. They have very good reviews so I'm not concerned about tthem but the guy did say that a common problem with the vectra was the air con condenser failing. I have a 57 plate cdti Sri 150bhp.
    Hes quoted £260 for new part fitting and charging the system if it is that.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    here is a few threads i found for you
    http://www.vectra-c.com/forum/search...earchid=175428
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    when mine was not getting cold enough i just took a gamble and got it re gassed for 40 pounds but that was a few years ago and its been fine since
    i believe its around 50 pounds now for a re gass
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Regular Member pompey-pimp's Avatar
    Nov 2009
    Fareham Hampshire
    Vehicle : BMW 520D Touring
    Trim : M Sport Business
    Engine : 2.0 d
    Year : 2010
    I got mine vac'd and regassed at Kwik fit on Saturday. They charge £49 and if there is no difference in temp then you don't pay. He tested mine and said that it was holding pressure but there was no temp difference so didn't charge, happy days but I thought the system was knackered as the missus had left it off for so long. Anyway driving down the road I flick through the settings and noticed the aircon was turned off. Turned it on and instant cold air. It was a bit smelly and because it had sat idle for so long I used an aircon cleaner and now the whole car is smelling nice and it's cold inside.
    I would recommend taking it to kwik fit as it's no loss if it doesn't work where as the others will charge for it regardless
    Not teaching you to suck eggs but do you have it turned on in the menu?
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    I re-gassed mine a couple of weeks ago at work and I've noticed I've got a couple of very small pin holes in my condenser (uv dye in the oil) at the moment it's working fine but when it packs up I'll just chuck a new condenser in and re-gas it at work (for free )
    Sep 2010
    northamtponshire
    I may need to buy some eggs, but... Turned it on in the menu?? What menu
    Nov 2009
    Fareham Hampshire
    Engine : 2.0 d
    Year : 2010
    On mine i have a dial button that when i push it it accesses the main menu on the centre dash screen from where i can select aircon on or off.
    11 Post(s)
    Quote Originally Posted by babilon2 View Post
    Only applies if you've got climate control. Because CC runs all the time, you can go into a menu via the CC panel and switch the AC into eco mode.
    Sep 2010
    northamtponshire
    Ah right, no climate control here just a pretty little button with a snowflake! Well the guy is turning up tomorrow and will do the pressure test and uv dye stuff and we shall wait and see what the diagnosis is!
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. Aircon
    By GoldenWonder in forum Bodywork & Interior
    Last Post: 20th June 2012, 18:18
  3. aircon help
    By jimmywhu in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 01:33
  4. aircon
    By eminemme42 in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2012, 13:32
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
