Thread: Airbag Light staying on
    Jul 2012
    Reading
    Default Airbag Light staying on
    Hi Can anybody help me withmy 2008 vectra SRI Estate. I was retrieving a lost metal planner blade which had slip down between the drivers seat and the Centre console. I couldn't grab it with my hand as fear of cutting myself so i used a magnet.
    As soon as i started the car the airbag light stayed on.
    checking the hand book later only to find that magents near the centre console are a big no no.
    does anyone know how I can get the light out (seat belt tensions have not been triggered)
    Nigel
    11 Post(s)
    Usually the only way is Tech2 (or similar diagnostic equipment)
    You might have disturbed the wiring under the seat during retrieval.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    May have disturbed wire.
    Try disconnecting batt for half hour.
    Make sure you've got stereo code tho
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    as above sound like you have knocked some wires under the drivers seat
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Typically, the one fault lamp you cannot extinguish with a battery disconnect is the airbag lamp. Due to the potential safety implications of a faulty SRS (Supplementary Restraint System) it should only be reset by diagnostic computer.
    Even once you're certain all connections are good - the common loose plug being under the front seats - you will need to get it 'plugged in'.
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    38 Post(s)
    Engine : 1.9 DTH
    If u trawling around HEATHROW area I can turn light off for ya mate FOC
    11 Post(s)
    Quote Originally Posted by Critch View Post
    Not needed for a 2008 Vectra as full canbus.
  1. Airbag light staying on longer after the car has started
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2012, 13:37
  2. Oil light staying on
    By Jamesie82 in forum Engine & Drivetrain
    Last Post: 12th May 2012, 22:31
  3. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  4. TC and ABS light staying on?
    By JonSRi150 in forum Engine & Drivetrain
    Last Post: 31st December 2009, 22:10
  5. Battery Light Staying on
    By phil67 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd April 2009, 21:22
airbag light on 2008vectra
vectra c airbag light stays on
vectra c abs light stays on site:www.vectra-c.com
vauxhall astra airbag light staying on
