Results 1 to 10 of 11
Thread: Aux Belt Tensioner - 2.0 DTi Engine
    Nov 2009
    Leeds
    Default Aux Belt Tensioner - 2.0 DTi Engine
    The mount for the aux belt tensioner has snapped clean off!!!
    Does anyone know what it has snapped off from? Is it an engine mount, sub-frame or ...? I've no idea and am trying to assess if and how much this is going to cost to put right.
    From searching on here it doesn't seem to be one of the more common faults, I can't find anything similar at all.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    look at the right hand side mate next to ya hand thats where is droke from
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    I think it is the belt tensioner that has snapped. It's a bit difficult to see. The belt tensioner is a removeable and replaceable item.
    Have a look at the How 2 about replacing the belt tensioner, it might help.
    http://www.vectra-c.com/forum/showth...59#post1537659
    Nov 2009
    Leeds
    Yes, I can see where it has snapped off, the silver 'c' area is shiney clean freshly snapped metal, with a matching section bolted to the bottom of the tensioner.
    The top of the piston connects to the belt tensioner arm.
    The bottom of the piston connects to the frame/engine/ engine mount/something and it is this that has snapped. there is a little lug with a drilled hole that the bottom of the piston bolts to, literally, the lug has cracked off.
    Nov 2009
    Leeds
    This is it, I nicked it from that how 2. Whatever the piston bolts to has cracked.11052011493.jpg
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    Nov 2009
    Leeds
    The part that has cracked is whatever bolts to this. It is not the tensioner itself that is cracked, it is what the piston bolts to.3d60_12.JPG
    Nov 2009
    Leeds
    Nov 2009
    Leeds
    As the bracket is under the air con pulley, is it part of the air con assembly?
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    just had a quick trawl of ebay to see what pics i can find , this is one of a full engine http://www.ebay.co.uk/itm/VAUXHALL-V...#ht_500wt_1287
    looks as though you need to drop the aircon pump & then the bracket is behind it .
  1. fan belt tensioner
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 15th December 2012, 11:50
  2. Aux Belt Tensioner
    By tatters40 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2012, 23:02
  3. aux belt tensioner
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 13:12
  4. Fan Belt Tensioner
    By betty02 in forum Engine & Drivetrain
    Last Post: 9th April 2011, 13:15
  5. Aux belt tensioner
    By jamesr in forum Engine & Drivetrain
    Last Post: 15th December 2008, 20:56
signum 2.0 dti aux belt
