Results 1 to 3 of 3
Thread: Air Gon :(
    May 2011
    Stockport
    Default Air Gon :(
    Hi guys. Wonder if anyone has any ideas on where to start when air con packs up? (Vectra DTi 54 plate)
    I had it gassed last year, and the system is still under pressure. It was working one morning, then when I got back in the evening, it wasn't
    I have checked all the fuses, the button lights up as it should, and when idling the engine revs dip slightly when I turn it on as I would expect.
    No untoward noises from anywhere. (Apart from a brief 'tapping' when the temperature control is turned right up, or down. Is this normal? )
    Anyone have any suggestions as to what to try next? Is there a relay involved somewhere?
    Thanks in advance
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Heater control flap stuck?
    May 2011
    Stockport
    Ooo... how do i check that?
