Thread: Another Climate Control Issue. Help please....
    New Member Murdoch Troon's Avatar
    Jul 2012
    Brisbane
    Default Another Climate Control Issue. Help please....
    Apart from my "Hello, I am new" post, this is my first official post.
    So, I have a pre-facelift Vectra C CDX with full Climate Control. Here's the thing. The fan control rotary switch began to die. When you turned it, it would change the fan speed in any order 7-2-3-6-4-1-5-0 and that sort of thing. It would operate erratically, and from the reading I did online, the whole panel needed to be replaced.
    So off I went to ebay, discovered that they were cheaper if purchased from the UK, and imported one. The one that I received has a silver bezel on the large rotary dial, but that's the only difference I can see. I have since discovered that this means it comes out of a facelift car. The part number has one digit different as well, but the look identical. On opening both, the circuit boards are identical too.
    I popped in the replacement part, and everything seemed ok. Fan control works properly, all the lights on the panel come on and off. The aircon appears to come and off, and the message in the display consol confirms this.
    Except, the aircon does not actually come on any more with the new panel installed. So I took the new part out, and replaced it with the dodgy unit. And bingo. The aircon works 100% again.
    Were the post-facelift cars so different that even the climate control panels changed? Anybody had a similar issue? Have I just wasted $100 on a part?
    Any thoughts would be most welcome.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Hi Mate
    well i can let you know in about 1 week.. i have a prefacelift vectra, that i will be replacing a prefacelift ECC module with another prefacelift ECC module. that hopefully should work i my car, but remember most modules are coded to match your car.. the module im getting is "pre coded, and changed to match my car" else i have to get to the dealers to recode it again.
    But if i remember correct, then there is small wiring change between prefacelift and facelift (yes you got a facelift module).
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    have you pressed the centre button & made sure there is a tick for air conditioning , it could be switched off in the new unit , although it would probably say ECO in the display if this was the case .
    Jul 2012
    Brisbane
    Thanks for both responses.
    Kenp, let me know how that goes.
    DTi Elite, absolutely. This was my first port of call.
    Appreciate the replies so far.
    Engine : 2.2 Direct
    Ive just received my "new" ECc panel from the uk.
    It was from a prefacelift to a prefacelift, althou i had it tech2 change via a user on here As i wanted a new funktion i wanted. And changed it to LHD from RHD. (Ive used the friendly user Tramman on here to buy, code, ans ship to mé)
    Just been out testing for like 20 seconds. All working As it should (so far). And Got my extra function ;-). And didnt even have to swap facia (i thoght i neede to.)
    So now the old goes A's spares. Or what i want.
  1. Climate control temp display issue
    By Greebo in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2012, 14:11
  2. 05 Elite Climate control issue
    By graham22vti in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2011, 11:41
  3. Climate Control Fan Issue
    By sjanisz in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2009, 11:28
  4. Climate Control
    By liphook in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2008, 04:10
